bravo issue
Old 06-19-2006 | 07:10 AM
boatfreak's Avatar
Default bravo issue
I had my boat out for its first good run of the year over the weekend and found I have a problem. When I shift into forward there is a two or three second delay before the prop turns. When I shift into reverse there is no delay at all. The thing runs great and makes no funny sounds at all just the delay.
boatfreak is offline
Old 06-19-2006 | 08:05 AM
Default Re: bravo issue
The begining of the end!! I'm no drive expert, but I had the same problem when shifting into reverse. Had it looked at and found gears severly pitted and I think the delay going into gear is caused by worn clutches??
Have it looked at now!!
Pure Energy is offline
Old 06-19-2006 | 08:08 AM
pachangalpina's Avatar
Sounds like the cable needs to be adjusted. It may not have enough travel in the cable and is trying to engage and then catches. The mounting stud for the cable in the engine compartment many have moved and need to be adjusted. Try shifting with the helm cable disconnected and see how it reacts.
pachangalpina is offline
Old 06-19-2006 | 09:51 AM
OOOPPPS, I may have jumped the gun!!! Could be a cable adjustment. Sorry!
Old 06-19-2006 | 10:32 AM
Grog's Avatar
I would try an adjustment also.
I have also seen that type of behavoir from a worn shift cable. Good luck.
Grog is offline
Old 06-19-2006 | 12:29 PM
Payton's Avatar
Charter Member #927
Mike, don't worry about it. It gives a moment for one more sip of beer.
Payton is offline
Old 06-19-2006 | 12:34 PM
carney's Avatar
I think merc updated the shift bracket in the drive, I changed mine a couple years back.
carney is offline
Old 06-19-2006 | 02:35 PM
boatfreak's Avatar
Yea I hear ya Mark and you know me well but when you are trying to maneuver a boat to tie up or dock in the wind that extra three seconds can make things very interesting.
Old 06-19-2006 | 03:20 PM
mats's Avatar
Check the cable between the transom assembly and the drive. When the cladding is about to give in it becomes difficult to get it into forward gear.
mats is offline
glastron
18
04-01-2006 11:37 PM
russ
0
07-21-2005 04:35 PM
DJW
04-06-2003 08:49 AM
