Oil psi
Old 06-20-2006 | 08:23 AM
Default Oil psi
What does everyone think? Had a stock 330hp 454 put in a melling high volume oil pump had a steady oil psi of 60 hot (electric) gauge. Built the motor everything a 420 clone put in a new melling high volume oil pump mech gauge reads 50 psi hot after a hard run 5100 for maybe 2 min oil psi goes down to 42psi back to cruise 3500 back up to 48-50psi. Running 30 wt oil. How come a old used motor would carry better oil psi?
k24u is offline
Old 06-20-2006 | 08:40 AM
Default Re: Oil psi
Sounds like your running good #'s to me. Pumps and bearings have diiferent clearances' , etc.. Mech gauges and electric gauges never read the same. If you want more pressure go to thicker oil.
kennyo is offline
Old 06-20-2006 | 08:49 AM
Default Re: Oil psi
Bearing clearance.
cstraub is offline
Old 06-20-2006 | 08:56 AM
mopower's Avatar
Toxic FORMULA
Default Re: Oil psi
Pressure's not terrible. Bearing clearances are probably the culprit. Heavier oil or larger oil cooler would help.
mopower is offline
Old 06-20-2006 | 09:55 AM
Default Re: Oil psi
ditto, I'd run heavier oil
thedonz is offline
evaluex
3
07-06-2008 05:09 PM
GoFastSonic
General Racing Discussion
4
05-27-2008 11:39 AM
osen007
11
09-20-2006 10:09 AM
Hot Boat
6
08-03-2006 11:25 AM
puder
15
03-30-2002 02:13 PM
