HP500 Oil Pressure >
HP500 Oil Pressure
HP500 Oil Pressure
Old 06-21-2006 | 09:58 PM
G Man's Avatar
Default HP500 Oil Pressure
What should the oil pressure of my HP500 be at idle?
G Man is offline
Old 06-22-2006 | 09:56 AM
Default Re: HP500 Oil Pressure
25-35lbs hot after a run I think. My 454/420's with 300 hours are about 25lbs hot.
MILD THUNDER is offline
Old 06-22-2006 | 05:56 PM
Pwrbt33's Avatar
Yeh, any where from 20 to 30 psi is fine on a stock oil pump.
John S.
Pwrbt33 is offline
Old 06-22-2006 | 06:52 PM
Gordo's Avatar
Charter Member #94
After a long hard run mine will go down as far as 16-18 at an idle in gear. Get back on plane and it goes right back up to 40 or so.
Abby-someone
Gordo is offline
Old 06-22-2006 | 09:45 PM
G Man's Avatar
Well, at initial start up in the drive way with 25/ 40 oil I have 75 to 100 lbs. Can that be right? I redid the dash panesl which means I had to take all the gauges etc out. I am parinoid I wired something wrong. I do not remember what it was lawst year before I took everything apart.
Can this be right when cold?
G Man is offline
Old 06-22-2006 | 11:05 PM
Gordo's Avatar
Charter Member #94
If it's stock with low hours, I guess it could be. But it does sound a little high..
Abby-someone
Gordo is offline
Old 06-23-2006 | 10:00 PM
G Man's Avatar
yeah stock HP500 with low hours. Anyone else ?
thanks
G Man is offline
Old 06-23-2006 | 11:35 PM
99fever27's Avatar
thanks
Whats low hours?
99fever27 is offline
GoCiggie31
7
08-19-2007 06:07 PM
FlyFast
13
05-10-2004 11:39 PM
sleeker
12
03-08-2004 06:02 AM
Racing_Fan
7
09-17-2002 09:19 AM
