How fast should I be going? >
Old 06-28-2006 | 04:35 PM
Leathl_WS6's Avatar
Default Re: How fast should I be going?
Originally Posted by 1BIGJIM
So what jets did you end up going with? THe last set of pictures looked good.
The primaries are 88's and the secondaries are 90's.
Leathl_WS6 is offline
Old 06-28-2006 | 04:38 PM
Leathl_WS6's Avatar
Originally Posted by PatriYacht
I used to have a 30' Scarab with 420's and TRS drives. It weighed 6800 dry according to the factory. It went 70 with 23 pitch 3 blade cleavers. This size boat always seemed to run well with 3 blade props. With almost 100 hp more a side you should be able to spin 25 pitch Mirages.
That is exactly what I thought. I have been wondering if the props I have have been reworked or are messed up. I have not had any luck finding another set of 25's to try. I found some 24 hydromotives I'm going to hopefully try out this weekend.
Old 06-28-2006 | 04:39 PM
Leathl_WS6's Avatar
Originally Posted by Holy Smokes
Any interest in trying a set of 23P Mirage's? It's what I'm running now and would love to swap and try your 22P Bravo's.
I would like to try the 23 mirages as well where are you from?
Old 06-28-2006 | 06:26 PM
You might be hitting the wall with your ignition system. try something in at least one of the engines to see a difference. I have a friend w/ a 1988 sutphen 31 w/ 502 magnums, 410 HP (repowered w/ 502mpi). boat does 78 mph on gps. running 26" hydromotive Q4 labbed. 5100 rpm aprox.
JIMG is offline
Old 06-28-2006 | 08:14 PM
rmbuilder's Avatar
MarineKinetics
Leathl WS6,
It is difficult to tell from the lighting in the photos. It does appear you are a bit cold on heat range and the jetting is inconsistent from cylinder to cylinder. Some of the plugs do not appear to have a full turn of color. Can't see the base of the insulator from the photos.
Perhaps this will help
Bob
Attached Thumbnails How fast should I be going?-spark_plug_readings_proper_heatrange2.gif   How fast should I be going?-plugs-copy.jpg
rmbuilder is offline
Old 06-28-2006 | 08:22 PM
rmbuilder's Avatar
MarineKinetics
Second photo
Old 06-28-2006 | 09:52 PM
Leathl_WS6's Avatar
Originally Posted by rmbuilder
Leathl WS6,
Bob
That middle plug is from #7. I was thinking of upping the jet on the rear port side of both motors. I am having a hard time getting color on that plug. Keep in mind as well those plugs were only ran for about 2 minutes and were brand new when they went in.
The heat range are you thinkin I should be runnin a hotter plug? Or I should add timing? Won't adding timing will move the mark you are pointing out. Most of the plugs have a reading like your picture for the heat range That one is the worst one. The others are a lot closer to middle of the electrode.
I did notice the jetting is inconsistent what causes that? If I run all 4 jets the same I'm too rich down low or lean up top.
Another thing too those plugs are from 2 and 7 on each motor so those are the leanest plugs I have. Running the Air Gap intakes those cylinders have longer runners.
Thanks Rob
Old 06-28-2006 | 09:58 PM
Leathl_WS6's Avatar
I thought the thunderbolt ignition was good to 6k I am only planning on turning it 5400 to 5600 max.
I would be very happy with those speeds and feel I should easily be able to run that.
Thanks Rob
Old 06-29-2006 | 06:41 PM
Leathl_WS6's Avatar
I double checked the timing tonight and it was higher than I had thought I'm not sure if the light i used last time was bad or what but timing aswas 36 on one motor and 37 to 38 on the other...
Yikes.
I'm going to try and get back in the water tomorrow.
hauling ass-a
01-17-2013 07:42 PM
ziemer
03-18-2007 08:34 AM
Emaginashun
12-20-2005 06:37 PM
Tom Earhart
Eliminator
19
10-18-2004 08:34 AM
Cattitude
1
08-01-2004 09:51 PM
