1.36 bravo 1 >
1.36 bravo 1
1.36 bravo 1
Old 06-26-2006 | 11:08 PM
Default 1.36 bravo 1
allot of my friends and blowing up there bravo 1 1.5s how much horsepower are they rated for. and is there a difference between the 1.36 and the 1.5.
I'm contemplating going with an XR upper so I'm not to have more problems.
LAXBAJA is offline
Old 06-26-2006 | 11:24 PM
GOODT's Avatar
Default Re: 1.36 bravo 1
other then tooth count no differance
xr is the way to go other then imco or bmax ect...and imco uses same gear set but better housing
GOODT is offline
Old 06-27-2006 | 12:52 AM
articfriends's Avatar
If your not running a ton of power the new style bravo's with thicker floors in the gears seem to be pretty good for longevity,I think it was 2002 when they went to them. I'm running alot of power in front of a max worxs drive,when I only had 700 or so hp they lasted pretty well in my 272,now that its cranked up over 900 hp my lower gears last about 40-50 hours. Your running a gen 6 502 mpi,a good bravo should last you though, if you really are abusing it step up to a xr but as far as a aftermarket drive I don't see the need in your case,besides,you'll have 10 g's plus wrapped up in it,Smitty
articfriends is offline
Old 06-27-2006 | 06:23 AM
OK sounds great. Ill leave it alone. My need to go faster is only really going to result in a bigger boat.
thanx again,
Curt
LAXBAJA is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
