Installing Flush Cleats >
Old 06-27-2006 | 08:57 PM
Default Installing Flush Cleats
I'm getting ready to replace my standard surface mount style cleats with pull up flush mount style. What would you guys reccommend to cut the deck? The instuctions say to use a saber saw!
Thanks, Dave
David Stotz is offline
Old 06-27-2006 | 09:12 PM
eyezlee's Avatar
Default Re: Installing Flush Cleats
I drilled a hole to start then used a jig saw. I duct taped the saw foot to prevent marring the gel coat. Its easy if you can get past cutting a hole in your boat. While you are doing it go ahead and get the flush mount bow light too.
Look here for all the parts.
http://www.acconmarine.com/
eyezlee is offline
Old 06-27-2006 | 09:19 PM
MOP
Ditto on the above just finished installing mine tonight, Sears has a very nice narrow blade that cut very well and follows curves well. Cut slowly and the cut will stay plumb, if you push it the blades tend to walk off being vertical. Use the backer plate supplied with the cleats for a template and cut right in the line the cleats will drop in with no filing.
Phil
MOP is offline
Old 06-27-2006 | 10:48 PM
Sydwayz's Avatar
Forum Regulator
ROTO-ZIP
Use a Tile Cutting bit, not the wood/plastic bits. Works like a charm.
Sydwayz is offline
Old 06-28-2006 | 05:59 AM
I did the following and it worked great:
Mask the surface with tape
Use the backing plate as a template and the drill holes for the screws
Insert screws into backing plate and thru hull to hold plate in place
Use a 1/2" drill bit and make pilot holes
Use sabre saw and cut the hole for the cleat
Remove backing plate
Use a Dremel with a sanding drum to clean up the hole until the cleat fits perfectly.
synack is offline
Old 06-28-2006 | 06:56 AM
Airpacker's Avatar
Roto Zip for sure. Doesnt tear up the glass like a jig saw can.
Airpacker is offline
Old 06-28-2006 | 08:59 AM
Steve Zuckerman's Avatar
Roto Zip, used the backing plate as a template, on top of several layers of wide masking tape.
Worked very well.
Steve
Steve Zuckerman is offline
Old 06-28-2006 | 11:22 AM
Thank you for the advice so far. I can't use the backing plate as a template as it is a different shape than the hole for the cleat. I am using the Attwood stud mount cleat so there are no exposed fasteners. They supply a template to use as a cut out guide. The masking tape on the deck is a good idea I never thought of. I think I am going to try the roto-zip tool but still not sure! Cutting the deck makes me nervous!!!!!!
Thanks, Dave
Old 06-28-2006 | 12:16 PM
Queenie's Avatar
Roto Zip all the way and ditto on the masking tape. You'll have no problems with the zip.
Queenie is offline
Anarchy Powerboats
05-11-2006 12:10 PM
Monty
12
03-24-2005 08:18 PM
Quiet Storm
3
02-10-2004 06:17 PM
JohnJan
01-06-2003 01:11 AM
GO4BROKE
Sonic
9
08-15-2002 06:20 PM
