Best pulled motor times >
Old 07-07-2006 | 08:20 AM
resurrected's Avatar
Default Re: Best pulled motor times
I used to pit with a NASCAR Craftsman Truck team, low budget so we swapped engines alot... roll in the garage 35min. later roll out of the garage!
resurrected is offline
Old 07-07-2006 | 12:18 PM
klmken's Avatar
What size tractor is that in the middle photo? I have one that looks the same and didn't think it would move the boat......
klmken is offline
Old 07-07-2006 | 12:59 PM
Originally Posted by nordic95
The best way I have learned to remove motors is to hire someone else to do it. I'm just to cheap
Me too. I can r & r mine in about 3 hours. My buddy has a similar truck, but much shorter boom. Only problem is its an hour drive from me. So I guess 5 hours total.
Where I live that 3 hours of time saves 600-1000 bucks!
jmherbert is offline
Old 07-07-2006 | 07:33 PM
Anthony...............what did you do now ????
I hope you can get those things back in just as fast.
Im curious as to why you pulled BOTH motors ???
otis311 is offline
Old 07-07-2006 | 07:48 PM
nordic95's Avatar
Its a BX 23 Kobota.I welded up a mount for the front and used existing holes in the frame.I made the ball changable and I use the tractor to move all my trailers around the yard.That is my garage the boat is parked in front of.I have 1.5 inches on each side to get the boat into the door.No way I could do it with the truck,so I made this work.Works perfect
PS I tapped a wire into my head light switch and to trailer so I can lock out brakes in reverse by just turning lights on.
Nordic95
nordic95 is offline
Old 07-07-2006 | 07:50 PM
nordic95's Avatar
Otis,
as you know this is my first boat and I was trying to get the oiled drained through the dip stick tube.I couldnt turn the hole boat upside down so I pulled the motors to flip them.Worked out great.I'll see you next weekend on your lake.PARTY TIME
nordic95 is offline
Old 07-07-2006 | 07:54 PM
drypipetiger's Avatar
Sorry for your troubles this time of year. I've been there.
drypipetiger is offline
Old 07-07-2006 | 07:59 PM
nordic95's Avatar
Thank U but
I WILL BE BACK
nordic95 is offline
Old 07-07-2006 | 10:16 PM
my old boat 89 201 liberator pulled drive sundeck rear seat motor and changed rear main seal 3 hours by my-self in the drive-way in 85 degree heat and put the boat back together and in the water but I was about 30 years old back then
k24u is offline
Old 07-09-2006 | 08:01 AM
Tantrum's Avatar
Thank U but
I WILL BE BACK
Great news, I had a feeling it would work out just fine.
That was very nice of you to pull the motors so Cathy could clean the bilge
Tantrum is offline
