Bravo XR drive >
Bravo XR drive
Bravo XR drive
Old 07-06-2006 | 02:09 PM
seahawk's Avatar
Default Bravo XR drive
What is the life expectancy of a Bravo XR.
When should it be serviced?
What parts break?
How do you make it last?
seahawk is offline
Old 07-06-2006 | 02:50 PM
Sydwayz's Avatar
Forum Regulator
Default Re: Bravo XR drive
What parts break?
About 1 really big launch and bad re-entry.
Good maintenance practice is replacing drive fluid every 20-40 hours depending on use. Pull the drive and lube the U-joints and check alignment at least once or twice a season.
Upper gears, lower gears, verticle shafts, cone clutches, U-joints.
Leave the boat on the trailer. (Seriously, baby it out of the hole, and go easy in rough water.)
Sydwayz is offline
Old 07-06-2006 | 02:55 PM
racer-x6's Avatar
[QUOTE=Sydwayz]About 1 really big launch and bad re-entry.
Got one in the shop right now with 15 Hrs on it,
racer-x6 is offline
Old 07-06-2006 | 03:13 PM
GOODT's Avatar
Brain (Sydwayz) is on the money as usual .......the least expencive thing you can do that means the most is changing the drive oil and as he said "one launch"
GOODT is offline
Old 07-06-2006 | 03:36 PM
I had problems until I started using amzoil gear lube in the drives and every spring remove the drives and bring them to the shop have them taken apart. Bring the gears and shafts to a machine shop and have the parts magnafluxed for cracks and just replace the bad parts before they explode. Much cheaper and dependable.
Ed
Scarab105 is offline
Old 07-06-2006 | 03:57 PM
seahawk's Avatar
racer-x6, How much will this be costing you?
seahawk is offline
Old 07-06-2006 | 04:03 PM
racer-x6's Avatar
Check with Marc at Bam Marine He will hook you up
racer-x6 is offline
Old 07-06-2006 | 04:10 PM
seahawk's Avatar
If the drive did'ent break and you took it in to have rebuilt (serviced/gone thru) what would that typicaly cost.
seahawk is offline
Old 07-06-2006 | 04:53 PM
GOODT's Avatar
do you mean dissasemble clean, inspect and reseale ????
approx 400.00 for upper 400.00 for lower + parts
GOODT is offline
Old 07-06-2006 | 05:01 PM
seahawk's Avatar
What ever is the recommended yearly or hourly service so that the drive will stay together.
Should these parts just be replaced every year as preventative maintenance???
seahawk is offline
