Sucking sound from 500 EFI ??? >
Old 10-19-2007 | 07:57 AM
  #31
Talking
Dock, did you wax the intake while you had the plenum off?
kennyo is offline
Old 10-19-2007 | 01:09 PM
  #32
Dock Holiday's Avatar
Charter Member #34
Well I'm glad to see this thread still here and still helping folks.
Actually if you have a reall good hydraulic shop in the area you can go and buy the o-rings for about .35 cents each. That is what I did once I found the right size and I keep a spare set in my shop.
Like Jeff said it is easy, you really cannot mess up and all they are is o-rings and not gaskets. Personally I would replace them all if it were me and I had it apart.
Good luck
Dock Holiday is offline
Old 04-25-2016 | 09:58 PM
  #33
Great post, I've learned a lot since I'm having the same issue on my 500efi, I'm also having surge issues, sounds like a 1071, can't imagine these issues are related,or are they?
BYFS is offline
Old 04-26-2016 | 12:04 PM
  #34
Swap the 2 IACS...Heck, swap the throttle bodies complete.
dereknkathy is offline
Old 04-30-2016 | 08:05 PM
  #35
Seems to me I had the same issue a few years ago so I'm a little fuzzy on the details, but I think I found I had low vacuum at idle & a large vacuum leak. The sucking sound may be air getting sucked past an almost completely closed IAC.
ctuck0659 is offline
tcm07
10-03-2008 02:00 PM
Elite Marine
20
09-12-2008 05:28 PM
JOJO
8
09-18-2007 01:45 AM
durbin3
3
02-12-2006 03:25 PM
gsmith9898
8
10-20-2005 02:25 PM
