Water pump inlet/outlet >
Old 07-16-2006 | 07:24 PM
Default Water pump inlet/outlet
On the sea water pump of HP500EFI w/standard rotation (clockwise) what is the sea water inlet? Top or bottom?
Can`t get pressure either way and it is hard to read on the back of the pump...
Hydrolift is offline
Old 07-16-2006 | 07:46 PM
GOODT's Avatar
Default Re: Water pump inlet/outlet
it depends on how the bracket is acclimated but normally the bottom is the inlet on std rotation......when installing new impeller did you pack with grease ?????
GOODT is offline
Old 07-16-2006 | 08:54 PM
I haven`t been out with the impeller. Just putting on a new hose for a friend, he took it out to get a new one and took of both without noticing where they went. It`s a realy narrow space and I can`t make out what it says on the back of the pump.
The pump is located down on the starboard side of the engine, it has the mec. fuel pump on the top. It is a stock Merc. HP500EFI pump.
I won't run the engine before I know I got it right.
Here is the pump http://www.mercruiserparts.com/Show_...+Pump+Assembly
Attached Thumbnails Water pump inlet/outlet-image12.jpg
Old 07-16-2006 | 09:21 PM
GOODT's Avatar
lower hose should be inlet
GOODT is offline
Old 07-16-2006 | 09:24 PM
Vmax
2
07-06-2006 09:01 AM
boatman22
20
02-17-2006 02:23 PM
38KV
10
11-17-2004 07:06 AM
voodoo
3
10-23-2002 07:30 AM
28SS
2
04-19-2002 03:16 PM
