New motor won't line up >
Old 07-20-2006 | 11:42 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Default Re: New motor won't line up
Did you use a drive alignment tool ??? If not use one of those before you go crazy.. My guess is the bearing may be out of alignment...
Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 07-21-2006 | 12:22 AM
Jamie / Lakeside
Yes I am using one and that's how I've come to this conlusion. The engine is low in the back.
I bought new fiber washers, coil lock springs and spacers. Can I double up the fiber washers?
ghittner is offline
Old 07-21-2006 | 05:38 AM
cig1988's Avatar
If I'm not mistaken the transom plate has an adjustment in it. Was this removed ? By the looks on the transom plate all the holes are ob-longed up and down.
cig1988 is offline
Old 07-21-2006 | 08:25 AM
nordic95's Avatar
Did you try raising the front of the motor?Remember the motor will pivot on the rear mounts,raise the front to lower the rear.
Nordic95
nordic95 is offline
Old 07-21-2006 | 08:34 AM
Nordic95
Rear is too low.
ghittner is offline
Old 07-21-2006 | 08:42 AM
nordic95's Avatar
Did you try taping the alignment tool side to side and up and down to center gimble bearings?
nordic95 is offline
Nordicflame's Avatar
When you say you R&R'd the bell housing, do you mean you installed a new one?
There are two different style motor mount bushings in the bell housing. Do you have the right one?
88791A1 and 865329A02
This will effect the alignment.
Dave
Nordicflame is offline
Old 07-21-2006 | 08:50 AM
Transom plate was not removed, however I did change the bolts and nuts one by one, no movement though.
ghittner is offline
Dave
Same bell housing, but good thought!
ghittner is offline
Old 07-21-2006 | 08:51 AM
I'm going to lift the rear now with a picker, I'll post what I find in a bit.
ghittner is offline
