Water in the cylinders!!!  Help. >
Old 07-28-2006 | 12:19 PM
Stormrider's Avatar
JC Performance Engines
Unhappy Water in the cylinders!!! Help.
Helping a friend.
Small block had water in a cylinder.
Supposedly bad/leaky exhaust. Had them replaced.
Now has water in 2-3 of the cylinders!
Any suggestions?
Stormrider is offline
Old 07-28-2006 | 05:13 PM
BY U BOY's Avatar
Default Re: Water in the cylinders!!! Help.
Helping a friend.
Any suggestions?
BLOWN HEAD GASKET.
BY U BOY is offline
Old 07-28-2006 | 05:19 PM
GOODT's Avatar
As stated bad head gasket do a compression test or a leak down test will tell all
GOODT is offline
Old 07-28-2006 | 05:23 PM
dean51267's Avatar
Joe,
Questions:
On a later model MPI motor, can that plug straight into a carb motor? I am going back into changing motors and have found a pair of 502 MPI's the guy swears will bolt right in place of mine and hook up and run.
Thanks!!!!
Dean
dean51267 is offline
Old 07-29-2006 | 10:37 PM
could also be loose intake manifold
thedonz is offline
Old 07-30-2006 | 07:04 AM
Payton's Avatar
Charter Member #927
or internaly leaking exhaust.
Payton is offline
Old 07-30-2006 | 07:20 AM
GOODT's Avatar
Originally Posted by dean51267
Joe,
Questions:
Thanks!!!!
Dean
yes, it will
GOODT is offline
gofastwannabe
10
06-01-2008 06:23 PM
Prostreeter
27
05-02-2007 09:36 PM
DonMan
6
12-03-2002 07:03 PM
chris miller
7
06-19-2002 05:09 PM
sage1234
04-23-2002 08:39 PM
