velocity chine walk. >
Old 08-03-2006 | 10:24 AM
Shore Thing's Avatar
Default Re: velocity chine walk.
I have a 1995 26'/280. I don't know what kind of power you have or at what speeds you are chine walking. I run a 25" Hydromotive Q-IV with ZERO chine walk at any speed. That being said, I top out at 70mph, so if your walking is above that speed I can't help.
Shore Thing is offline
Old 08-03-2006 | 12:09 PM
Hemi Truck's Avatar
Talking Re: velocity chine walk.
I also have a 1995 26'/280, did some prop testing on Saturday and found some definite differences in the way the boat handles depending on which prop you use. I tested a labbed 28 bravo one, a labbed 30 bravo one and a 27 Hydromotive. Both bravo's handled pretty similar but the hydromotive was a totally different animal, it was so loose and chine walked like crazy. Best speed was 78mph on GPS with the 28 B1. I would suggest trying other props depending on what power you have and speeds you are currently running. Hope this helps.
Hemi Truck is offline
Old 08-03-2006 | 02:11 PM
Dock Holiday's Avatar
Charter Member #34
Pad bottom boats don't like a lot of trim.
We over trimed the first 30 Outlaw and it did it bad. Dropped the drives and the speed picked up and it run super.
I would play with the trim and the props.
Good luck.
Dock Holiday is offline
Old 08-03-2006 | 03:52 PM
bglz42's Avatar
On my 26' Thoroughbred (Velocity) I never had an issue with chine walk. When I ran a Hydromotive, it'd walk a little. Just drove through it. When I switch to B1, no chine walk EVER. One of the best hulls I've ever driven...
bglz42 is offline
Old 08-03-2006 | 09:33 PM
I have a 2005 Velocity 260. First time I drove it I kept falling off the pad in the mid 70's which would then go into a chine walk. I just didn't know how to drive it. It just takes some seat time to learn how to drive it and keep it on the pad. Took some concentration at first, but have it down now. The boat is much easier to drive in rough water than calm. For good practice go out in 2 ft chop, head into the wind ,and run her hard. You won't believe how smooth it will run. Like the others said the prop you run has everything to do with handling. I also am running a Bravo 1 28P prop that I'm still dialing in. I haven't tried a Hydomotive prop yet but want to, as I've heard they run a little faster.
Revd Up is offline
Old 08-05-2006 | 02:21 PM
I have a 26' 280 that is procharged and I run in the 90 to 95 mph area. Props make a differance. With a hdromotive and stock at 70 mph it was a test you can steer out of it, Now with my current application Bravo 4 blades depending on gear ratio I have run from 28 to 32 labbed props and it runs straight as an arrow. I do not have tabs or need them. The labed prop with less lift seems to be the cure.
RBeyer is offline
RICHARD CUNY
Prop Talk
13
06-28-2008 11:47 PM
Chris Sunkin
08-29-2007 05:15 PM
paxtonsc
08-07-2005 04:43 PM
migara422
7
07-13-2004 06:56 AM
Fightclub
03-18-2004 08:48 PM
