#6 HP consumption >
#6 HP consumption
#6 HP consumption
Old 08-15-2006 | 01:21 PM
Strip Poker 388's Avatar
Rob
Default Re: #6 HP consumption
Originally Posted by cougarman
Yes they do and have for some time, all the 41' Sabers have them.
I have two of them I'll be putting for sale also.
Cougarman
I thought the 6's came with a merc style extention box. I guess the transom assy kinda looks like its built in??
Strip Poker 388 is offline
Old 08-15-2006 | 02:21 PM
cougarman's Avatar
The way I have understood it is Mercury's transome assembly already has you set back 12" so most boats have no need for the box.
However some boats still benifit from an additional 12" so the Stelling's extension box comes into play.
Check300 has his transmission in side of his stellings extension box, mounted into a plug-in #6. He was able to keep his engine back and a stock rear seat location. He could fill you in better, but he has a great set-up.
Cougarman
cougarman is offline
Old 08-15-2006 | 04:30 PM
Rob
Cougarman
Thanks for the info.
Anybody got a pick of a Merc extension box on a #6?
Old 08-15-2006 | 04:31 PM
what's up w/ the hoses sticking up from the plate just over the prop shaft. Looks like it would ventalate???
tomcei is offline
Old 08-15-2006 | 04:56 PM
Post #20 shows the stock Merc Box bolted to the Stellings.
RumRunner is offline
Old 08-15-2006 | 04:57 PM
You need to ventalate the real big props to get up on plane.
Old 08-15-2006 | 06:42 PM
cougarman's Avatar
What are ya looking for on pic's, ?
I have two boxes on the floor.
Cougarman
Old 08-15-2006 | 10:35 PM
Rob
Cougarman
Does merc make a evtention box like Stelling? or is it just built into the transom assy?
So if someone want more set back that the merc like in your pick they have to use the stellings?
Just trying to learn about them,thanks
Old 08-16-2006 | 07:11 AM
So does anyone know the exact hp loss thru a #6 and its tranny.
Pismo10 is offline
Old 08-16-2006 | 08:37 AM
cougarman's Avatar
No , Mercury's set back ( is ) there Transome assembly.
Anything additional is Stellings.
Attached Thumbnails #6 HP consumption-drivesyellow6.jpg   #6 HP consumption-drivesblue6.jpg   #6 HP consumption-number6drive3.jpg
