Who has the best 4" Exhaust Tips? >
Old 08-16-2006 | 09:30 PM
Default Who has the best 4" Exhaust Tips?
Looking at replacing my old 4" stainless exhaust tips due to one of them burning out. It had a combination metal/rubber flapper inside. I see new tips out there that appear to have all rubber flappers and others that advertise a "super flapper". What are the best ones to use? I'm looking for longevity and don't mind spending a few more dollars to do it right. Who's the best? Harden, Teaque, Rex? Do you have a part #? I just need the straight normal length tips. Thanks
Corbs is offline
Old 08-16-2006 | 11:02 PM
Default Re: Who has the best 4" Exhaust Tips?
Corsa will last forever. But they are noisy at idle.
Griff is offline
Old 08-17-2006 | 02:17 AM
rexone's Avatar
Corbs our tips are all heavy .083 wall T316L Stainless with heavy flanges, hand polished. Our Superflapper™ is quiet, and guaranteed for Life, even on blown and turbo applications. With over 7000 in service, 4 known failures. You will not find a finer quality exhaust tip.
We will also retrofit our older tips with the original "no burn" flappers (welded shaft). We stopped building these approx 4 years ago. While they didn't burn, they did break on blown stuff and we're standing behind them. They also rattled pretty good on motors with big cams. That is the reason we built the Superflapper™ which by the way is not welded in and can be easily replaced if ever necessary.
Here is a link. Please let me know if you have any questions or need more info.
rexone is offline
Old 08-17-2006 | 08:13 AM
dykstra's Avatar
Originally Posted by TRICK
Stainless Marine. Lifetime warranty on the internal flap.
agreed
dykstra is offline
Old 08-17-2006 | 07:36 PM
G Man's Avatar
I did a lot of research on this for my 25 Outlaw with HP500. I wanted something good looking, not too short and not too long, good sounding, and that would last. Tried a bunch and settled on Stainless marine that I bought from Trick Marine. Very Very pleased with both Stainless Marine and Trick. Highly recommend!
Good luck
G Man is offline
littledcsrodshop
Swap Shop
17
08-31-2008 02:57 PM
bolgna
4
01-23-2008 06:23 PM
Allatoonaoutlaw
1
04-01-2007 08:27 AM
Blue by You
06-12-2006 07:57 AM
blackhawk
08-21-2002 06:57 PM
