House/starting Battery >
Old 08-17-2006 | 08:31 AM
Default House/starting Battery
I have an 88 baja 235 force, question is how do i determine which is my house battery from my starting battery. Thanks for any input. One of the batteries has quite a bit connected to it of which i'm presuming that would equate to being the house? I need to connect a power cable to run an amp and speakers. Thanks for your Help!
brew80 is offline
Old 08-17-2006 | 09:19 AM
Default Re: House/starting Battery
more info do both batt. have sep. grounds or is ground for one of the batt. a jumper you are using a batt switcher yes ?
eliminatethis is offline
Old 08-17-2006 | 09:36 AM
Hey thanks for the input... Yes I am using a switcher but am not sure if the batteries have seprerate grounds. I don't recall anything connecting between the two batteries. ? I know vague.. thanks for the help
brew80 is offline
Old 08-17-2006 | 11:25 AM
each boat is diff butt when i rig for 12v sound with amps. i run sep. grounds to batts. switch output gets eng. harn. and acc. that need to be used when starting and running like blowers , hatch batt #2 gets sound syst. hooked direct to it throught a breaker close to #2 batt as you can than ran to amps when the eng are off i switch to batt #2 when starting i switch t0 #1 and when eng are warm i switch to the both setting on high end systems i never start the eng with the batt on both and the sound playing i do not want to spike the amp with low volt i also run 2 batts in parralel on house batt #2 depends on system
Old 08-17-2006 | 11:49 AM
Hey thanks a lot bud ... I apreciate the input... happy safe boatin this weekend
brew80 is offline
Old 08-17-2006 | 01:01 PM
Iggy's Avatar
On my Formula both batteries are wired to supply power to the entire boat.
But, I do have a cranking battery and a deep cycle. The cranking batt is just for starting. The other batt I use when anchored.
My battery switch has #1-#2-Both-Off positions. Batt #1 is for starting, #2 is the deep cycle (house) batt. I can use either batt for starting but it will damage the deep cycle if I continuously use it that way.
Iggy is offline
Old 08-17-2006 | 02:54 PM
so am i able to differentiate with the switcher, being on 1 or on 2, which is my starting battery from the house ? I dont recall if it was on 1 or 2 but it would start on one of those, i switched it to all and it fired right up... thanks guys
brew80 is offline
BAJA WILL
02-26-2008 08:12 PM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
MiamiVice
7
03-11-2005 10:43 AM
luvlake
0
03-16-2004 04:55 PM
KAAMA
18
09-19-2002 11:02 PM
