compression for blower motor >
Old 08-20-2006 | 03:13 PM
nocigarette's Avatar
Default compression for blower motor
whats the best compression for a 540 eagle h beam rods and crank jesel valve train inconnel valves j e pistons, thinking 671 blower need advice ,,,,,,,,,,,,,,,
Attached Thumbnails compression for blower motor-magnum-015.jpg   compression for blower motor-magnum-021.jpg
nocigarette is offline
Old 08-20-2006 | 03:26 PM
ratman's Avatar
Default Re: compression for blower motor
671 is way too small for a 540, 1071 to 1471 will work for you and 9 to one is the max static compression. give dean gellner or jc a call they will point you in the right direction
ratman is offline
Old 08-21-2006 | 03:48 PM
depending on the boost level you would like to run and octane of fuel, I would like to see 8.5:1 if you 9.0:1 you can still be safe just keep the boost down 5 PSI or less. At 8.5:1 compression I have run 7-9 PSI of boost with iron heads and have no problems. 30 degrees to 32 on timing. 92 octane with intercoolers.
mrhorsepower1 is offline
JRider
18
08-28-2008 12:49 PM
CcanDo
18
08-17-2008 10:34 AM
fantastixvoyage
12
06-19-2007 06:09 AM
boatman747
12
01-27-2005 03:34 PM
