Oil Filter might beat me >
Old 08-30-2006 | 12:07 PM
Re: Oil Filter might beat me
Get a remote oil filter mount set up put where you can get it.
Badtoon is offline
Old 08-30-2006 | 01:18 PM
Default Re: Oil Filter might beat me
Go Gators! $2 screwdriver is right...I spent ~ $100 on every conceivable oil filter wrench @ NAPA, several worthless wonder tools, pipe wrenches from Home Depot, not to mention I ruined my Old Reliable 25+ yr old filter wrench and the screwdriver worked.
I thought about the remote oil filter when I had the engines out last month but I've never had this problem before. I think the guy who installed the engines for me had to have put a wrench on the filters, but who knows. I installed the filters and ran the engines in my garage before I brought them to be installed.
Thanks again for the suggestion, I had setup to pull the engine out yesterday but figured I'd give it one more shot Monday...Busted up fingers / arms and a few ounces of blood...Now I have extra grand for gas money
Island Time is offline
Old 08-30-2006 | 02:24 PM
K&N, they have a nut right on the bottom.
rdp145 is offline
Old 08-30-2006 | 03:17 PM
sleeper_dave's Avatar
If their oil filters are anything like their air filters, you might as well just put an empty can where your oil filter goes.
sleeper_dave is offline
Old 08-30-2006 | 10:08 PM
It is worth mentioning that oil filters tend to come off much easier when the engine/filter is good and warm. You also have the benefit of draining the oil with more particles suspended in the oil when the engine was just run.
4mulafastech is offline
Old 08-30-2006 | 10:28 PM
dykstra's Avatar
Agreed
dykstra is offline
Old 08-31-2006 | 02:40 PM
Wobble's Avatar
SORE MEMBER
I have had very good luck with this type of wrench, better that screwdriver IMO
Wobble is offline
Old 09-01-2006 | 12:24 PM
I started with warm engines but this one wouldn't budge.
I used that exact belt wrench to squeeze the oil out of it...Crushed it to about half its size. It would have worked if I had more space to turn the Socket. I could only turn it about 1/8th of a turn. Once the belt had tension on it, it would stretch.
Old 09-02-2006 | 11:13 PM
Grog's Avatar
I helped a buddy of mine remove his oil filter the other night from his new boat SBC. Space was very limited. Obvoiusly, the moron that installed the prior filter did such with a wrench (I think it was factory).
It was a "the strain popped a vein in my forehead" removal, but it came off. Luckily, we did not need to resort to extreme measures. It reminded me of removing lug nuts from a wheel after the idioits at Discount Tire installed them.
Grog is offline
Velocity Vector
0
04-03-2008 01:45 PM
powerguy
5
08-04-2002 07:44 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
