Scan results....need help >
Old 08-31-2006 | 01:49 PM
hp500efi's Avatar
Member #9
Default Re: Scan results....need help
Originally Posted by Cord
Sounds to me like the engine is going bad. I'll give you $50 and take the problems away tonight.
LOL, how are you and Deanna?
Heading to the river this weekend for probably our last trip out there this year. Have a safe and fun labor day weekend.
Member of the Liquid Jungle
hp500efi is offline
Old 08-31-2006 | 03:09 PM
Maybe you ought to slap some big ol carbs on them motors and that will get rid of all those silly codes.
By the way just in case you forgot, I still have'nt seen the boat.
RonS is offline
Old 08-31-2006 | 06:28 PM
hp500efi's Avatar
Member #9
Problem found!
Pressure sensor clip was broke and fitting was open enough to get moisture inside the connections and corrode. I cleaned it out and tested, all OK. Now all I need to do is get a new sensor and put back together.
Thanks to all!
Hey Ron and Cord ....
hp500efi is offline
Old 08-31-2006 | 07:21 PM
Downtown42's Avatar
i like happy endings
Downtown42 is offline
Old 08-31-2006 | 10:42 PM
Dave M's Avatar
Veteran: Navy
DIACOM SW is pretty nice! Takes the guesswork out.
Dave M is offline
Old 09-01-2006 | 06:55 AM
u still have one problem-the fact that you arent running the boat like it should be run wot bumpin the rev limiter-
mr mercruiser is offline
Old 09-01-2006 | 08:52 AM
Nordicflame's Avatar
"Sea Pump Pressure 43.46 PSI"
This one jumped right out... 43.46 lbs at idle
Got to love the Diacom
Nordicflame is offline
Old 09-01-2006 | 08:53 AM
That's a nice looking boat Jeff, but I would prefer a beer and a tour, then again I'll buy you a beer if you ever get that thing off of the river and out on the big pond.
RonS is offline
Old 09-01-2006 | 03:02 PM
Official OSO boat whore
Guess I've had my head in the sand...when did you upgrade to a Sonic?
Deanna and I have been good. This last year has turned around 180 degrees for us. We are both working way too many hours. Gonna have to force some time off before something breaks.
Cord is offline
Old 09-08-2006 | 10:29 AM
Originally Posted by hp500efi
Dave, are you talking about the sensor attached to the pump housing that senses water temperature? If so, I know what to look for.
Oh, and is the motor in the 90% Guardian mode? if so, can I erase the fault codes to get it back to 100%?
Thanks much!!
Jeff
Hp500
Sounds like same thing that happened to me,had a seawater impeller fail and shortly after that the 2 alarm trouble started..
I`ll double check that sensor on the pump...did u replace yours and how much was it?
tnx
bcolmsted is offline
