Rev limiter
Old 10-06-2006 | 10:44 AM
Mike Paula's Avatar
Default Rev limiter
I don’t have the PN with me but on my old 1990 330hp 454 with the Thunderbolt ignition ( I am pretty sure is a V8-24) system what was the rev limiter set at?
Mike Paula is offline
Old 10-06-2006 | 10:48 AM
Dave_N's Avatar
Default Re: Rev limiter
Tbolt IV modules do not have a rev limit function.
Dave
Dave_N is offline
Old 10-06-2006 | 01:47 PM
No rev limiters on TB IV's. On Blue engines with TB IV's they use a separate rev limiter.
Griff is offline
Old 10-06-2006 | 04:48 PM
Strip Poker 388's Avatar
Rob
and i wouldnt buz it over 5000rpm.I think its rated at 4800????
Strip Poker 388 is offline
Old 10-06-2006 | 09:54 PM
My '89 330 was good to 5500 extended runs and up to 6000 bursts for six years then it stuck a valve from bad riser gaskets. It's a really good stock motor!
ghittner is offline
Old 10-06-2006 | 10:53 PM
Rob
[QUOTE=ghittner]My '89 330 was good to 5500 extended runs and up to 6000 bursts for six years then it stuck a valve from bad riser gaskets. It's a really good stock motor![/QUOT
You must of did some work to it?
My 365 mag with headers,1.8 rockers,and holley 830 carb was flat about 5400
Old 10-07-2006 | 09:55 AM
Mike Paula's Avatar
I have the same ignition system from my 330 hp 454 on my 500hp 502. I cant seem to get over 5100 rpms out of it. So are you saying there is no rev limiter on this motors system?
Old 10-07-2006 | 10:57 AM
BY U BOY's Avatar
THAT IS CORRECT NO REV LIMITER. 5100 IS WERE YOU WHANT TO BE
BY U BOY is offline
Old 10-07-2006 | 02:11 PM
[QUOTE=Strip Poker 388]
Just prop size and timing on that motor
ghittner is offline
Old 10-08-2006 | 03:46 AM
Yep, NO rev limiter.
Griff is offline
D Harry
4
06-28-2007 07:20 AM
D Harry
0
06-23-2007 04:26 AM
motoman450
1
04-25-2005 03:01 PM
THRILLSEEKER
6
07-25-2002 07:30 AM
KENNY
2
06-10-2002 11:38 PM
