Salt Away ??? >
Salt Away ???
Salt Away ???
Old 10-11-2006 | 07:22 AM
Default Re: Salt Away ???
Works great! A must when running in the salt!
mrhorsepower1 is offline
Old 10-11-2006 | 07:28 AM
i've been using it for years flush the motors and wash the boat and trailer.you would never knew it came out of salt water.
sonic28 is offline
Old 10-11-2006 | 07:53 AM
offthefront's Avatar
Originally Posted by cig1988
In my case I'm limited to the duration I can idle my boat. I've had the PD warn me that next time they visit I will have a $500. fine. So I compromise and flush at the public marina the last several times. Last Sunday was told by the harbor master if I do again I will be banned from the marina. Oh yeah, I pay over $2500. a season for a slip but that dont matter.
Seems you might come up with a quick clamp on or slip in muffler just for flushing ...m
offthefront is offline
Old 10-11-2006 | 07:54 AM
I called & spoke to Lenora yesterday at Salt Away. She seems awesome to work with & may be able to give a group discount indivudally. If this seems like a good idea let me know & will run it by her. The prices she gave me yesterday was alot lower than retail providing you purchase by the case. 4 gallons per case. While plowing in the middle of night I get that harsh salt prior to road traffic. This will definetly be a test.
I would be interested in a "group" buy ......m
Old 10-11-2006 | 07:58 AM
Ted G's Avatar
How about a couple of hoses into a bucket of water from the exhaust?
www.cbpba.com
Ted G is offline
Old 10-11-2006 | 08:22 AM
BajaBennett's Avatar
I use a product called SaltX (704) 391-8111. It is about the same as SaltAWay. I pulled my heads last spring and the heads look new. I flush after every run and then use the SaltX. Well worth the $ for the peace of mind.
Dail
BajaBennett is offline
Old 10-11-2006 | 08:59 AM
ericaull's Avatar
I gotta look into this stuff, never seen it , gotta try it......
ericaull is offline
Old 10-11-2006 | 09:33 AM
I use it religously. I flush with fresh water for a while then switch on the salt-away and shut the motors off when the salt away is about 3/4 gone.
I also keep a spray bottle with a 50/50 mix of water and salt-away to get everything that may have gotten wet under the hatch.
Dangerous Dave is offline
Old 10-11-2006 | 09:54 AM
cig1988's Avatar
Next season I'll have a truck or bus muffler with a "Y" pipe & 2 lengths of flexable rubber exhaust hose. Should work like a dream. Good thought though.
cig1988 is offline
Old 10-11-2006 | 09:57 AM
cig1988's Avatar
Will get back shortly with the 3 hour time change. Interested in the 4 gallon/1 case ?
cig1988 is offline
