Bennett Tabs >
Bennett Tabs
Bennett Tabs
Old 10-14-2006 | 06:23 PM
nordic95's Avatar
Default Bennett Tabs
Hey guys I have Bennett trim tabs on my Formula and was wondering if it was possible to put a trim gage on them and how are they mounted?Where would I get a set up from?Any help would be appreciated.
Thanks Nordic95
nordic95 is offline
Old 10-14-2006 | 07:21 PM
stageharbor's Avatar
Go Big or Go Home
Default Re: Bennett Tabs
yes they make a trim indicator set it requires replacment of one ram cap on each side it has a wire in it that goes to a module in the dash and an led indicator on the dash. you should be able to get them at any marine store
stageharbor is offline
Old 10-15-2006 | 09:29 PM
Full Force's Avatar
I think you could run mechanical indicators too,I may get a set of gaffrig ones from a friend to try it.
Full Force is offline
Old 10-16-2006 | 05:08 AM
Iggy's Avatar
The Bennett trim indicator requires that you disassemble the rams to install a sensor then the installation of the indicator and wires.
Kit is available from Bennett or through most marine stores.
Iggy is offline
Old 10-16-2006 | 08:02 AM
Shooter's Avatar
Charter Member #300
My Sonic has mechanical. Looks like a hole was drilled and ther ya go.
Shooter is offline
Old 10-16-2006 | 09:46 AM
I have Bennett LED indicators, I don't like them too much. The back lighting was out on one of them and was not just a bulb to fix. Also the range of the indicators didn't seem to match the range of the tab.
When I painted my engine compartment this year I did not reconnect the sender wires and plan on installing mechanical indicators from Lovorsi this winter.
http://www.livorsi.com/catalog/mecha...CAL_INDICATOR_
Shah Mat is offline
Old 10-16-2006 | 01:37 PM
We have a first class mechanical set. Very easy install. Stainless Marine
BROWNIE is offline
Old 10-16-2006 | 02:53 PM
Sydwayz's Avatar
Forum Regulator
Definately do NOT get the Bennett LED kit. Its not favorable for our type of boats.
Sonic installs a mechanical setup just like on the K-planes. I would definately go this route. I can't remember, but I had mechanical indicators on my Bennetts on my Sonic. I think the indicator was mounted to a bolt on the part of the tab that the rams attach to. Perhaps someone in the Sonic forum can provide a picture of how this is setup. Most of the 26' Sonics are this way. I believe the 25' Baja Outlaw is often setup this way as well. I don't recommend the Bennett LED indicators. Too man issues.
Brownie above and Fred at www.trickmarine.net would be places I would talk to.
Sydwayz is offline
Old 10-16-2006 | 03:02 PM
bennett LED wasted my money stainless marine the only way to go .
mismanagement is offline
Old 10-16-2006 | 04:02 PM
Shooter's Avatar
Charter Member #300
pic
Shooter is offline
ItsPeanut
5
08-04-2008 09:28 AM
twanger
7
12-13-2006 09:21 AM
PierPressure
3
07-06-2006 10:00 PM
S4Hadi
9
02-27-2006 11:15 AM
leviathan
11-23-2004 08:53 AM
