Winterizing HP525's >
Winterizing HP525's
Winterizing HP525's
Old 10-14-2006 | 07:28 PM
slboatdrinks's Avatar
Default Winterizing HP525's
I have HP525's with Bravo XR drives with dual raw water pickups.. Factory installed fresh water flush T'd into the raw water hose from the outdrive. I saw this quote on another thread in Q&A. Is this the correct way to run antifreeze into the raw water system? Should you still drain the manifold risers first?
"I have a tee that I screw into the garden hose adapter for winterizing. 1 end water supply, other end to 5 gallon bucket full of antifreeze. Run the motors until up to temp, shut the supply leg off, open the antifreeze. Instantantly sucks the antifreeze down."
slboatdrinks is offline
rssteiny
1
10-11-2006 09:45 PM
bglz42
6
09-14-2005 10:16 PM
Dean Ferry
Nordic
2
12-23-2004 09:09 AM
bowtie89
5
12-16-2003 09:27 PM
Rippem
7
10-01-2003 01:35 PM
