Help! Rocker Arm Question for 502 Gen 6 (1998)
Originally Posted by GNJ
I changed from the stock 3/8" and had 7/16" studs put in the heads at a local machine shop. Now the rocker balls do not fit the studs and I have to do something else.
Does the jessel system fit under stock valve covers and without any mods?
OK, thanks to all for the input so far.
I am convinced to go with full roller rockers.
What stainless steel roller rockers would be good and fit under the stock cover? It seems some members have had issues with the aluminum ones, although that may be on higher lift applications. (I am running a .527/.544 lift roller cam)
Any advice would be greatly appreciated.
