Which prop
Old 10-27-2006 | 08:03 PM
Magnum25's Avatar
Default Which prop
Can someone give me advise on what prop to use for my Mach 1? I am going to put a BravoXR drive with a 502 And a procharger on my Mach1.I was thinking about a 26 pitch ss prop.What do you guys think?
Magnum25 is offline
Old 10-29-2006 | 05:29 PM
Default Re: Which prop
How big a boat? What gear ratio? Estimated HP? Weight? etc.
RBeyer is offline
Old 10-30-2006 | 09:48 PM
I also would like some advise....I have a 26 Sonic and next year a whipple charger will be on it pushing around 660hp.
I have a bravo X drive 1.5 ratio what prop do you think I should get for my debut with the Whipple?????
I was running a bravo 24.5 4 blade at 5050 rpm's on the stock
496HO for 66.7 mph on a good chop.
Do you think a 4 blade 28 or 3 blade 30 ?
Bad-Intentions is offline
Old 11-01-2006 | 04:12 PM
AIR TIME's Avatar
m 25 what prop do you have now if your running a 3 blade then start with a m27 or b1 26/ B I WITH THE SONIC start with the b1 28, or 29m I have 670hp 2'' shortie in my OL24 RUNNING 5900RPMS AT 83 GOING TO USE bblades this spring he has a prop swap set up we will try stock max 26 and 28 plus 28 bi then pick one and lab i want to run between 5400 to 5600 rpms and 85mph he's thinking.
AIR TIME is offline
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
