engine lift???? >
engine lift????
engine lift????
Old 11-25-2006 | 08:27 AM
offthefront's Avatar
Default Re: engine lift????
http://cgi.ebay.com/Portable-Jib-Cra...QQcmdZViewItem
Portable Jib Crane
BRAND NEW, DIRECT FROM MANUFACTURER
AUTHORIZED DISTRIBUTOR
Product Number: JIB-P-10-10-10
Delivered to you in 10-15 Days
Designed for use in multiple locations, includes jib crane and one base socket. Extra base sockets may be purchased for use in other locations. Friction brake design allows positive locking and controlled rotation of heavy loads. 360° continuous rotation of heavy loads. Handle most applications up to 1,000 lbs. and up to 120" radius reach. Standard 4" high I-beam on all units with 2.663" flange width. Rugged welded steel construction. Hoist and trolley sold separately, request separate quote, if needed.
Multi-Station Transportable Jib Cranes
Model Span (Feet) Usable Height (Feet) Capacity (lbs) Net Weight (lbs)
JIB-P-10-6-6 6 6 1,000 284
JIB-P-10-6-8 6 8 1,000 304
JIB-P-10-6-10 6 10 1,000 324
JIB-P-10-8-6 8 6 1,000 300
JIB-P-10-8-8 8 8 1,000 320
JIB-P-10-8-10 8 10 1,000 340
JIB-P-10-10-6 10 6 1,000 316
JIB-P-10-10-8 10 8 1,000 336
JIB-P-10-10-10 10 10 1,000 356
JIB-P-B Extra base socket, 31"H with 12"x12" base
offthefront is offline
Old 11-25-2006 | 11:52 AM
Strip Poker 388's Avatar
Rob
Originally Posted by Comanche3Six
thats about the price of a forklift
Strip Poker 388 is offline
Old 11-25-2006 | 05:25 PM
Comanche3Six's Avatar
A gantry is expensive....a forklift is a dangerous way to change engines
http://aolsearch.aol.com/aol/redir?s...ion=WebResults
Comanche3Six is offline
Old 11-25-2006 | 06:24 PM
http://cgi.ebay.com/ws/eBayISAPI.dll...MakeTrack=true
jackhammer is offline
Old 11-25-2006 | 06:32 PM
http://www.synthx.com/btw/crane.htm
Old 11-25-2006 | 07:57 PM
Panther's Avatar
Frank's Marine Service
I've used forklifts numerous times and as long as the lifting assembly doesn't put all the weight at the end of the forks they're safe.....
I too am looking for a gantry or something that I can assemble in my driveway to pull the engines etc. I'd have to measure but I figure I need at least 6-7 ft. of lift to pull the motor, plus the height of the motor to the top of the gantry/come along and about 9-10 ft. width...
There's a guy down the street that has one, I need to knock on his door and see where he got it. I've seen him lift boats with it and the steel beam is about 12-14 in. thick!
Panther is offline
Old 11-26-2006 | 11:19 AM
Here you go. I see these in use at Bayway Refinery.
Old 12-25-2006 | 04:04 PM
jeff32's Avatar
I use the same u-shape boat lift to pull my engines out. Not too expensive and I can lift the boat from the trailer quite easily, plus it is made with bolts so I can store it when I don't need it. To mount it I need someone else, 2 man is enough... pictures to come tonight...
jeff32 is offline
Old 12-25-2006 | 11:38 PM
Panther's Avatar
that's exactly what I'm looking for.
Did you buy it or fabricate it?
Panther is offline
Old 12-26-2006 | 07:38 AM
jeff32's Avatar
Had it made to my spec to fit in my garage. a customer of mine I sell truck to did it. He has a welding shop. I think it was around 850-900$ canadian funs so a little less for you I would say...
jeff32 is offline
