Water Pump
Old 11-10-2006 | 08:23 PM
gripit's Avatar
Default Water Pump
Can somebody explain to me why the engines in this pic doesn't have a water pump on the front of the engine.
gripit is offline
Old 11-10-2006 | 08:32 PM
Ted G's Avatar
Default Re: Water Pump
They have crossovers that take the place of the circulating pump. The cooling system can be fed all the way through by the raw water pump and the circ pump is not needed on a raw water cooled boat. You can actually lower temps in high perf engines by removing the circ pump, and it takes a few horsepower to spin it at higher RPMS.
www.cbpba.com
Ted G is offline
Old 11-10-2006 | 08:53 PM
gripit's Avatar
Are their any advantages of the circulating pump?
gripit is offline
Old 11-10-2006 | 09:00 PM
Ted G's Avatar
On an engine that is already set up with it (belts, hoses, etc.) it takes some work to convert over and on some engines it will raise water pressure so a regulator may be needed. Also you can't use a thermostat so getting good heat will require different restrictors in the system, takes some tweeking to get it right.
www.cbpba.com
Ted G is offline
BillR
11
07-29-2022 06:31 AM
HP500Hammer
15
01-30-2008 06:03 PM
jdub
7
03-26-2007 05:06 PM
Jayl13
15
01-17-2003 03:17 PM
