Bowtie Small block heads >
Old 11-28-2006 | 09:12 PM
Default Bowtie Small block heads
How do these stack up? ANyone tried these out yet???
unbroken is offline
Old 11-29-2006 | 09:19 PM
Default Re: Bowtie Small block heads
I have some on some motors I had built that Im going to put in this winter.......mine are stage 3 iron angle plug.....supposed to be as good as anything out there with the possible exception of AFRs which are really expensive
pullmytrigger is offline
Old 11-29-2006 | 09:56 PM
Thanks, thats exactly what I have. Are yours EFI or Carb???
unbroken is offline
Old 11-30-2006 | 08:37 AM
750 double pumpers........
Old 11-30-2006 | 09:13 AM
Hey Trigger.....what rpm and mph increase did you get with the switch to revolution exhaust manifolds. If I remember, your engines are basically stock 350's, right? Looking to do the same thing but wanted to make sure it is worth the expense.
AGGRAVATION28 is offline
Old 11-30-2006 | 09:41 AM
the engines are bone stock......ask Powerboat magazine, unless you can do it in the same day to duplicate exact conditions for comparison top end blast is really hard (fuel, pass load, temp, wind, water conditions etc).....but for sure Ive picked up 250 to 300rpm.....definatly more muscle out of the hole and in the midrange too.......the motors are stock so its not a crazy amount but you can feel it......the 100lbs/side wieght savings is worth it......would I do it again vs Revs WAY more expensive competitors......in a heartbeat!!
Old 11-30-2006 | 05:22 PM
We've built many stock car engines with them and it's about one of the best heads you can use on a small block . My first boat was a Formula 202 I think was the model back in the 80's I built a 377 CI 400 block with a steel 350 crank and some 5.7 chevy rods I turned it 6800 with the bowtie heads and would run 73 mph on a three blade the heads were mildy pocket ported and gasket matched . Best of luck Laz
MESABALANCING is offline
Old 11-30-2006 | 06:04 PM
Thanks Guys, they are being blueprinted and c&c'd as I type. Look sweet, can't wait to get them done.
unbroken is offline
e8411a
29
03-20-2010 08:19 AM
Full Force
15
06-03-2006 07:24 PM
johnnyboatman
3
12-17-2004 04:27 AM
glassdave
12
10-19-2004 12:40 AM
timucin
8
09-29-2002 11:43 AM
