Spark Plugs
Old 12-12-2006 | 07:16 AM
Default Spark Plugs
Has anyone here run these plugs on a superchargered applicaton....Ac Delco R42TS?
I have been recomended to run them in a 500 EFI with an M3 - SC @ 5 lbs Boost Looks to be 1 heat range colder than the stock MR 43 T's the merc book call sfor in stock configuration.
Set the Gap @ .35 with stock ingnition.
Bryan
Bryan Rose is offline
Old 12-12-2006 | 07:54 AM
Crazyhorse's Avatar
Default Re: Spark Plugs
I've run the MR43T plugs in my supercharged carb 509 engines without problems but I don't run hard. Mine make 650@5lbs boost. But as I said, I don't run hard.
Crazyhorse is offline
Old 12-12-2006 | 07:59 AM
I've got the same setup as you. I run the 43t's also. When i ran the 42's they seemed to foul easier. Other than rusting, what is the difference in the mr43t and regular 43t's?
kennyo is offline
Old 12-12-2006 | 09:45 AM
BY U BOY's Avatar
THE ONLY DIFF IS FOR MARINE.
BY U BOY is offline
Old 12-12-2006 | 10:32 AM
Crazyhorse's Avatar
Yup, the M is a marine designation and they used to be stainless. Lately I've been buying the MR43T plugs and they have been painted steel.
Old 12-12-2006 | 12:05 PM
Bryan
In the older 525 SC Merc used the MR 41 T, a little colder plug than the MR 43 T used in the non blower motors. Ran them in the pair of 525 SC's I had and they always worked fine for me, better a tad on the cold side than melt down a piston.
RaggedEdge is offline
Old 12-12-2006 | 12:50 PM
I am running the MR41T with no problems. B&M 250 502.
Get pretty dark if you idle but clean right off once up to temp.
BadDog is offline
Old 12-12-2006 | 01:36 PM
I run NGK UR5's in my 525SC with a hotter cam and 7.5# of boost. They are the same heat range as the AC MR41T. Never had them foul out, but after a long idle in humid weather they are pretty dark.
Griff is offline
Old 12-12-2006 | 07:43 PM
Hydrocruiser's Avatar
Arrow Re: Spark Plugs
NGK's are my personal favortie. I use locktite anti-seize and get easy on and off's.
Hydrocruiser is offline
Old 12-13-2006 | 07:45 AM
What gap would you run on a procharged 502?
kennyo is offline
