good battery location??? >
Old 12-13-2006 | 10:31 PM
jhiguy377's Avatar
Default good battery location???
Hey guys, I just yanked all the wiring out of my 377 Scarab- want to redo it to a better standard. I'm thinking of putting my batteries under the rear seat in the cockpit near the sides. I did this years ago in my old Formula 302. It gave me a lot more room in the engine compartment and the new location was cooler and better vented; batteries cables only ended up being 4" or so longer. What do you think? - any really bad negatives? Thanks - Jeff
jhiguy377 is offline
Old 12-14-2006 | 06:11 AM
Payton's Avatar
Charter Member #927
Default Re: good battery location???
You are moving wieght forward. It may affect the handling of your boat a little. But, no more than one extra girl would.
Payton is offline
Old 12-14-2006 | 07:41 AM
i did exactlywhat you are suggesting and it worked very well. in my case on a 38 gun, it moved that weight almost right on the cg of the boat which helped everything as well as thye benefits you observe.
stevesxm is offline
Old 12-14-2006 | 08:39 AM
On a similar note, on a single engine boat, shouldn't the batteries be on the starboard side to help counteract the prop?? Mine are on the port side
bcarpman is offline
Old 12-14-2006 | 09:39 AM
Mine are on the starboard side to offset my weight
1BIGJIM is offline
Old 12-14-2006 | 12:20 PM
If you have a prop torque lean, it will help to move the batteries to the starboard side.
Griff is offline
Old 12-14-2006 | 01:05 PM
jhiguy377's Avatar
thanks for the info guys, I'm looking forward to a cleaner and more spacious engine compartment - Jeff
BAJA WILL
02-26-2008 08:12 PM
offshoresteve
Skater
16
02-26-2008 02:39 PM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
SSComp
Baja
7
05-05-2004 12:07 PM
TwoKs
10-08-2002 07:46 PM
