sEA WATER PUMP DRIVEN FUEL PUMP >
Old 12-28-2006 | 07:35 PM
Default sEA WATER PUMP DRIVEN FUEL PUMP
A quiestion for you guys about this, I have removed the fuel pump and installed a big electric Aeromotive pump that came with the pro charger. When I removed the mechanical fuel pump I noticed thet there was oilo in the area that the arm goes down into. Is this area fed oil from the motor or is it just a cavity that holds oil for the mechanical arm. I fired up the motor today and I guess there is a leak here because i noticed a good puddle of oil directly under the sea water pump....I did not put gasket sealer on itwhen installing the block off plate, so perhaps that is the problem, I am going to replace the gasket between the sea water pump and the block off plate and put sealer on it before torquing it down. Am I missing something here? Anyone enlighten me.
by the way this thing has some serious blower whine at idle, sounds good!
Bryan
Bryan Rose is offline
Old 12-28-2006 | 07:37 PM
Default Re: sEA WATER PUMP DRIVEN FUEL PUMP
That is just a cavity to lube the pump arm. Drain the oil, and reseal.
PPlay33 is offline
Old 12-28-2006 | 07:46 PM
Kind of thought that I will drain and re seal
Bryan
Old 12-28-2006 | 07:50 PM
DrNautica's Avatar
That oil, Mercury HP Gear Lube BTW, also lubes the shaft and bearing. Drain and refill with new lube and then seal.
DrNautica is offline
Old 12-29-2006 | 06:59 AM
Zero Patience's Avatar
Yep, it must have the oil to lube the shaft and bearings.
Zero Patience is offline
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
HP500Hammer
15
01-30-2008 06:03 PM
fastedy
6
06-05-2007 10:18 PM
David Haag
4
05-04-2004 08:32 PM
