T sat housing >
T sat housing
T sat housing
Old 01-05-2007 | 12:11 PM
BajaExpress's Avatar
Default T sat housing
Does anyone one have the proper adjustment procedure for the white ball and spring in the top water ports exiting the thermostat housing?
454 (330HP) 1987 model
BajaExpress is offline
Old 01-05-2007 | 02:47 PM
txriverrat2001's Avatar
Default Re: T sat housing
Never had to adjust them - clean the long ass bolt and put 'em in.
txriverrat2001 is offline
Old 01-05-2007 | 07:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I think the screw has a shoulder to bottom the nut out on. No adjustment. Been awhile. Anyway, that setup is a checkvalve, not a flow control part. The springs just keep everything together, allowing the balls to push out when the stat is closed (bypass route) and to allow the balls to somewhat seal preventing hot water to reenter the motor.
edit, is this the 2 balls and spring assembly?
US1 Fountain is offline
Old 01-07-2007 | 06:12 PM
Yes, two balls shaft and springs. If you tighten nuts until bottomed out, will this cause resistance to bypass?
Old 01-16-2007 | 07:26 PM
Refresh this thread. Does any one have any merc manuals that show this adjustment?
Old 01-16-2007 | 08:14 PM
Lofty's Avatar
I'll look now.
Lofty is offline
speedreeder
Wanted
1
04-04-2008 03:24 PM
ak
4
02-26-2008 05:38 PM
MOERON
11-23-2007 09:52 AM
