Fuel Pressure Regulator >
Old 01-08-2007 | 04:41 PM
DORaymond's Avatar
Default Fuel Pressure Regulator
Anyone have a source for an adjustable fuel pressure regulator kit for a late model GenVI 502 with cool fuel? The late models have the regulator bolted to the fuel pump in the cool fuel box, rather than a regulator on the end of the fuel rail.
I see that Hardin and Eckart have them for earlier model cool fuel setups.
Thanks.
DORaymond is offline
Old 01-09-2007 | 09:00 AM
Rage's Avatar
Default Re: Fuel Pressure Regulator
Thanks.
If the Cool Fuel box is the same as the late model 496HO, which I thnik it is, then the Vortech 8F130-018 fuel pressure optimizer will do the job. You have to whittle the plastic cool fuel enclosure some to provide the necessary additional clearance for the optimizer and cut the top off the existing fuel pressure regulator per the kit instructions. It works like a champ and comes in colors.
http://www.vortechmarine.com/products_04.php
Rage is offline
Old 01-09-2007 | 09:36 AM
mjb
I installed one on my cool fuel setup. I bought it from Arizona Speed and Marine but I have seen the same regulator kit available from several different sources.
It is not really a new replacement regulator. It is an adjustable retro kit that you install on the existing regulator. It is fairly easy to do and works well.
mjb is offline
Old 01-09-2007 | 09:53 AM
madbouyz's Avatar
Got mine from Teague
madbouyz is offline
Old 06-05-2011 | 02:07 AM
MikeScarab28XLT's Avatar
Old Thread i now, but intersting for me.
What PSI you adjust for a 502EFI with pressure regulator in the fuelrail, no cool fuel. Have you test it with air fuel ratio gaug ??
MikeScarab28XLT is offline
oldandtired
06-07-2006 06:09 PM
Rage
13
01-14-2006 05:53 AM
Rage
0
11-30-2005 08:09 AM
hauling ass-a
3
10-01-2002 11:10 PM
hauling ass-a
6
05-02-2002 01:53 PM
