crankshaft .0025 from front to rear ? >
Old 01-24-2007 | 04:41 PM
troc's Avatar
Question crankshaft .0025 from front to rear ?
is this acceptable? Just got all my parts back from the machine shop and after cleaning i started double checking
measurments. The gen IV crank measured from bearing 1-5
: 1=2.749 2=2.7485 3= 2.748 4= 2.748 5= 2.7465
Any thoughts thanks, troc
troc is offline
Old 01-24-2007 | 05:15 PM
blue thunder's Avatar
Default Re: crankshaft .0025 from front to rear ?
Seems like a lot. You will need to mix and match shell/sets halves to get the .003 - .0035 needed. That is not uncommon. Make sure your measurement method is accurate. I always sanity check with plastigage during final assembly as well.
BT
blue thunder is offline
Old 01-24-2007 | 05:58 PM
troc's Avatar
Plasti- gauge gets a bad rap. i am pretty confident on my measuring, should have the plastic! thanks for the reply. I will doubl check tommorow then start mixing and matching halves
troc is offline
Old 01-24-2007 | 07:02 PM
Troc,
The rear main is supposed to have almost .002" more clearance than the rest. As far as the diffference you are getting in the others, it is pretty normal for a stock crankshaft. You can mix some bearings if you want. Thats why we generally regrind every crankshaft in engines that we build. That is the only way to know they are correct
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 01-24-2007 | 07:16 PM
troc's Avatar
thanks bill, Is that because more load is occuring at the rear,so that allowance is made ? thanks again it is much appreciated , troc
troc is offline
Old 01-24-2007 | 07:44 PM
Troc,
I dont really know the answer, but if I had to guess I would say it was to pass more oil through the bearing, maybe to get to the thrust surface ? I may have to see what I can find out and report back .... inquiring minds must find the answer
Bill
BillK is offline
Old 01-24-2007 | 08:11 PM
troc's Avatar
thanks again bill, i will do the same on my end
Cort
troc is offline
Old 01-25-2007 | 04:42 PM
Lets us know what you find out Bill. I always shoot for .003 on 1-4 and .0035 on the main. I would think .005 on the main would be excessive. I have had oil temp problems in the past from time to time and often wondered if I wasn't tight in the main.
BT
Old 01-25-2007 | 06:49 PM
troc's Avatar
talked to machine shop today,same explanation as you Bill. rear is usually under .001-.002. larger bearing surface to support crank/oil for thrust surfaces. he did say he would not
run clearances greater than .035 in a bbc. I bought a set of .001 over bearings and split with std. and got my .025"
Thanks again Bill
cort
troc is offline
Old 01-25-2007 | 06:51 PM
Cort,
That was the same explaination I got from the guys at the AERA www.aera.org Larger bearing surface and more load.
Bill
BillK is offline
