What cam is this?! >
What cam is this?!
What cam is this?!
Old 01-25-2007 | 05:02 AM
tomas_wallin's Avatar
Default What cam is this?!
It's an flat tappet UltraDyne cam...
It has been in a blower 509.
The numbers I found on the cam is as follows:
J3854
272 282F14
15 16
200278
Last edited by tomas_wallin; 01-25-2007 at 09:58 AM. Reason: Not sure about hyd/mech lifters
tomas_wallin is offline
Old 01-25-2007 | 09:50 AM
rmbuilder's Avatar
MarineKinetics
Default Re: What cam is this?!
Originally Posted by tomas_wallin
It's an flat tappet UltraDyne cam with hyd lifters...
J3854
272 282F14
15 16
200278
Tomas,
Going strictly from decoding the serial numbers:
Mechanical flat tappet:
J3854 serial #
272º/282º Seat duration
238º/248º @ .050"
146º/155º @ .200"
.550"/570" lift valve
.3233"/.3353" lift lobe
114 LSA
15 16 (lobe master #)
This cam, when ground, was a solid flat tappet cam.
Bob
rmbuilder is offline
Old 01-25-2007 | 09:56 AM
Thanks alot Bob!
After some more research I honestly don't know if the lifters are hyd or mech.
But since it's a mech flat tappet cam then I assume the lifters are the same.
dmaxx3500
19
05-18-2008 07:59 PM
kingrich
3
05-11-2005 11:34 AM
JohnSchiavarelli
2
07-07-2004 02:48 PM
Leathl_WS6
55
12-10-2003 08:07 PM
Drew
1
02-05-2002 01:11 AM
