Best oil and sparkplugs? >
Old 01-27-2007, 08:38 AM
SORE MEMBER
Wobble's Avatar
Default Re: Best oil and sparkplugs?
Originally Posted by Prostreeter
Really.Maybe I'm doing something wrong.For my altitude which is 6k feet 10w30 I thought was a good weight oil.Perhaps you can advise me as well whats a good weight oil.
definitely the NGK v power plugs, very reliable and not prone to fouling easily
Many of us run 20/50 oil in our marine 502's and personally I prefer the Mobil 1 v-twin 20/50 or equivalent. Unlike a street motor, marine motors operate at a much higher torque load at all times and the oil has more work to do,
there are many opinions out here on the subject however.
I run my v-twin 50 hours with the m-1 filters. We also ran it in our modified lite dirt race cars.
Wobble is offline
Old 01-27-2007, 08:57 AM
Royal purple race 51, a little expensive but well worth it.
rssteiny is offline
Old 01-27-2007, 10:52 AM
Hydrocruiser's Avatar
Arrow Re: Best oil and sparkplugs?
In that setting I would use Amsoil Marine 15W-40 synthetic oil in a big block 502.
http://www.amsoil.com/storefront/ame.aspx
Let the engines warm up real good before hitting the sticks.
Hydrocruiser is offline
Old 01-27-2007, 10:56 AM
The original owner was using penzoil racing oil but I had several people tell me thats not a great idea
scarabsc is offline
Old 01-28-2007, 10:06 AM
Some racing oils do not have detergency additives and thus are meant for one race or "heat" and then drained. Carbon particles accumulate and cause accelerated wear in oils with no detergency; detergents and dispersants bind them up and keep them dispersed.
The 15W-40 Amsoil is as low that I personally would go in a multi-vis lube for a 502.
Quite frankly I would be surprised if Mobil-1 15W-50 would not do the job for you as it pumps well at lower temps.
Old 01-28-2007, 10:58 AM
Registered User
rrentsch's Avatar
For the last couple of years I've been running Kendall GT-1 straight 40w in my 502 mpi I had heard that the Kendall GT-1held better oil pressure than most oils because it would not airerate like other ? From what I've seen I will keep using it.
My new boat has HP500 efi's, what NGK plug would I use in these engines ?
rrentsch is offline
Old 01-28-2007, 11:49 AM
RED LINE ALL THE WAY NOTHING ELSE!!!!!!!!!!!!!!!!!!!!!! There 10 40 has the same viscosity as a 20 50. I used this in my blown 502 for 3 years almost 450hrs. Just tore it down to build a 522 the inside looked almost new! Champian race plugs!
2fastfountain is offline
Old 01-29-2007, 06:09 AM
A 10w40 can no way have the same viscosity as a 20w50, if it did they would call it a 20w50.
Ken
minxguy is offline
Old 01-29-2007, 11:34 AM
Ken
Redline states that their 10W-40 Syn has the same bearing and boundary lubrication properties as a conventional 20W-50.
Viscosity is still a 10W-40.
Ryan00TJ is offline
Old 01-29-2007, 01:38 PM
Thats what i was getting at relax GUY!
Quick Reply: Best oil and sparkplugs?
