Do your engine breathers smell? >
Old 02-01-2007 | 11:13 AM
rv
Default Do your engine breathers smell?
I am thinking on redoing the crank case ventilation. Current setup is 2 #10AN lines to flame arrestor. I was considering changing to the filtered type (K&N, Morso, etc) that mount to a tube on the top of each valve cover.
Does this type smell after running when you idle around our stop for a while? I am concerned the oil vapor will drift out of the engine compartment into the cockpit.
Rick
rv is offline
Old 02-01-2007 | 11:22 AM
OldSchool's Avatar
Default Re: Do your engine breathers smell?
Maybe a little bit....but I usually blame it on the dog!!
OldSchool is offline
Old 02-01-2007 | 11:42 AM
Rinse with Summers Eve
jeff1000man is offline
Old 02-01-2007 | 11:43 AM
Rick
I run these and I have no problems with any odors out of the engine compartment. I do generally run the blowers when I am idling or sitting still though.
Old 02-01-2007 | 01:29 PM
Mike Paula's Avatar
I do get a little. not bad
Mike Paula is offline
Old 02-01-2007 | 02:51 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Rick,
Are they back in the boat?
Did you dyno them what kind of power did they make?
Still on the quest for the Top Gun but waiting to pull the trigger till my condo sell in the keys
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 02-01-2007 | 11:49 PM
Strip Poker 388's Avatar
Rob
if the motor had some blowby you will smell it depending on the engine compartment , my Hustler you can smell it. I put the breater by he air intake and that took care of it.I do have blowby at 9lbs of boost.pistion to cylinder clearance is high on mine
I am changing my system up this winter #12;s and a Moroso puke tank that has a baffle ,fiter etc.we'll see?
Rob
Strip Poker 388 is offline
Old 02-02-2007 | 05:51 PM
I just changed mine back to the hoses to the flame arrestor. Had the K&N push in type filters. You do smell oil a little after running hard. Also I noticed a fine oil film over the engine after some long runs.
Revd Up is offline
Old 02-02-2007 | 09:31 PM
Hydrocruiser's Avatar
Arrow Re: Do your engine breathers smell?
Fleet
Hydrocruiser is offline
Old 02-02-2007 | 11:14 PM
Rob
Originally Posted by Hydrocruiser
Fleet
there bland the summers eve is all natural kinda salty
nocigarette
19
05-18-2006 04:05 AM
SeaWeasel
5
12-09-2003 09:22 PM
pb
10
09-08-2003 11:20 AM
kathycool
7
10-22-2002 06:40 PM
jdnca1
4
06-27-2002 12:14 PM
