Degreeing cam help >
Degreeing cam help
Degreeing cam help
Old 02-04-2007 | 02:03 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Degreeing cam help
A good test indicator is around $100. Starret, B&S.
Howza about take the piston to TDC, remove a valve spring and let it drop on top the piston. Then position a dial indicator on top of the valve stem? Then slowly moving the piston up and down just an 1/8" or so using the valve to follow the piston, reading the indicator? Just don't spin the motor over. Then again, if you did, you could just put the indicator on top of the piston at that time.
Whoops, seen you got it. Better start reading the post start to end before replying.
US1 Fountain is offline
Old 02-04-2007 | 04:09 PM
blue thunder's Avatar
Glad you didn't give me that idea early today Jerry, I'd have tried it for sure. I don't think I could get the spring off with the headers in the way though.
Bill, I am apparently not allow to post pics due to my frugality. I took some to post but forgot about that. Email me and I will shoot them to you. I moved and don't have your email anymore.
[email protected]
BT
blue thunder is offline
Old 02-04-2007 | 04:13 PM
Klaw, can you post a pic of your bullet? Sounds like a sweet old school ride. I'm into that you know.... if you need a good piston stop let me know
BT
GNJ
4
11-07-2007 09:19 PM
KEPP
0
05-19-2005 02:39 PM
kingrich
3
05-11-2005 11:34 AM
Leathl_WS6
55
12-10-2003 08:07 PM
timucin
8
11-24-2003 12:08 AM
