Air Conditioning, is it difficult to rig on a boat? >
Old 03-06-2007 | 03:50 PM
Brad Zastrow's Avatar
Default Air Conditioning, is it difficult to rig on a boat?
I need to install air conditioning to my canopy MTI. Is this difficult to install? Any ideas on what system to use and how to rig it? I did place a call to NautiCool. I am not sure if they sell to end users or not. I want to rig it myself. Not sure how much either.
Brad Zastrow is offline
Old 03-06-2007 | 03:55 PM
t500hps's Avatar
21 and 42 footers
I bought a 5K BTU Cruisair unit and installed it myself on a 31 ft Formula. Hope you don't mind drilling a few holes in your boat. It cost me about $1,500.00 and around 40 hours to complete the project. (you can look it up in old threads in the Formula Forums.)
t500hps is offline
Old 03-06-2007 | 03:57 PM
Panther's Avatar
Frank's Marine Service
Pretty easy actually! Mount it, locate the water pump/pickup, run the plumbing to the unit, locate the thermostat control, install an inverter and run the duct work.
Panther is offline
Old 03-06-2007 | 04:15 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You don't want this....
US1 Fountain is offline
Old 03-06-2007 | 04:18 PM
Ginger or Mary Ann?
So then I guess this is out too......
Old 03-06-2007 | 05:15 PM
Brad you are looking for something that you can run while under way are you not. I believe the setups above are for when you are already in a slip.
RonS is offline
Old 03-06-2007 | 05:21 PM
t500hps's Avatar
21 and 42 footers
OH....He's right, These things need a constant water supply and 120V.
t500hps is offline
Old 03-06-2007 | 05:40 PM
Panic Button's Avatar
Emerald Coast of Florida
I bought an Ocean Breeze 10k BTU with heat for $1200 off eBay included everything & digital thermostat, it took me about 20 hours to complete. The unit runs off a 2000w genset, and is not a reverse cycle heat, so you don't have to be in the water to run heat, you do for the AC...
Panic Button is offline
Old 03-06-2007 | 07:17 PM
Yeah, I need the system that runs off the engine much like a car. Weight is slight factor as well. It is going in a race canopy boat. Need to keep the cockpit cool at 100 mph.
Attached Thumbnails Air Conditioning, is it difficult to rig on a boat?-1.jpg
Old 03-06-2007 | 07:24 PM
Ginger or Mary Ann?
Hmmm, in that case redneck AC
.....hold you hand up in the air and make a scoop to deflect the air to inside. Cheaper and it works!
