HELP! ? on Gaffrig GPS Speedometer
If your Speedo is stuck at the 9 o'clock position it means there is no signal from the antenna, 12 o'oclock means the recall switch is stuck in the recall position, and 3 o'clock means the switch is tuck in the clear position. None of these "codes" actually mean the switch or the antenna are bad, it could be the wiring, the switch, or the speedo itself. We keep an extra of each at the shop for diagnosis, it's the quickest way to know what's going on.
Crazy Energy
Wiring
GPS SMARTCRAFT
http://www.livorsi.com/pdf/GPS%20SMARTCRAFT.pdf
GPS DIGITAL
http://www.livorsi.com/pdf/GPS%20DIGITAL.pdf
GPS MONSTER (little plugs)
http://www.livorsi.com/pdf/GPS%20MONSTER.pdf
GPS 3 3/8" (customer's antenna) (wire leads)
http://www.livorsi.com/pdf/GPS%20Instructions-ca.pdf
GPS 3 3/8" (Livorsi antenna) (wire leads)
http://www.livorsi.com/pdf/GPS%20Instructions-sa.pdf
GPS SMARTCRAFT
GPS DIGITAL
