-   -   Merc Bravo Drive Oil (https://www.offshoreonly.com/forums/general-q/153925-merc-bravo-drive-oil.html)
copiercat 03-19-2007 10:34 AM
aerospacelubricants.com
Knot 4 Me 03-19-2007 01:14 PM
I've used Amsoil in the past with good results. Never had a problem with the Merc HP.
Dave M 03-19-2007 07:39 PM
Originally Posted by NightHawk (Post 2062920)
I would agree about the Merc HP. I've run the same Bravo 1 outdrive hard for 15 years on the stuff. Wake hopping, water skiing and racing. On my second factory engine but never had to touch the outdrive so far. I am sure this is common.
I run the Merc stuff too. 600+ hours, lots of flight time, no problems.
Noise Pollution 03-19-2007 08:30 PM
Originally Posted by Pwrbt33 (Post 2062939)
I like to use the Mercury gear lube in the drives. I have tries Royal Purpleand have had gsome issues. Was it the oil? Who knows, went back to green and problems went away. Yet we run the Royal Purple racing 51 in some of the big motors we service and after its time to freshen up the engine builder said the inside looked great after 150 hours. 1150 Cobras. I use Mobil 1 and Valvoline Racing. Its all in what YOU think is a good oil. After all, Mercury oil lasted the warrenty period.
John S.:D
I had someone recommend using the same oil that is used in the # 6 drives to run it in a bravo drive when pushing over 600 hp. Thoughts?
Scott 03-19-2007 10:21 PM
One thing about the Merc green it does mix with water. This is a must in my opinion:cool:
Hydrocruiser 03-20-2007 06:53 PM
Good seals matter most.
Did you test your seals with a pressure/vacuum tester before adding in the new lube?
You should ya know. :evilb:
Scott 03-21-2007 08:09 AM
Hydro I may be reading into your post too much and your right but failure can happen at anytime. This is why I like a lube that will mix, it may save the day if you have a small leak before the next oil change.
OldSchool 03-21-2007 08:49 AM
I run the mercury green in my #6's and have run it in all of my previous Bravo's without any issues.
Pismo10 03-25-2007 07:49 PM
What is the Merc Green? Is that Merc HP drive lube?
US1 Fountain 03-25-2007 07:50 PM
Yes
