Prop rotation on Single >
Old 03-22-2007 | 09:41 AM
mats's Avatar
Well, I disagree. A left spinning engine (as seen from the stern) rolls the boat to starboard. When the burning fuel pushes the pistons down and push on the crank it will create a force in the opposite direction and hence lead to a right spinning torque on the engine block and the boat which the engine block is bolted to (as seen from the stern).
mats is offline
Old 03-22-2007 | 10:35 AM
Pat McPherson's Avatar
Well, I could be wrong, and it would not be the first time, but engine rotation is viewed from the front of the engine. A left hand engine turns CCW as viewed from the front.
Patrick
Pat McPherson is offline
Old 03-22-2007 | 01:20 PM
mats's Avatar
Well, this may be the miscommunication, I think you should view the engine from the flywheel end of it when defining what is right (CW)and left (CCW). http://www.propowermarine.com/faq-rotate.htm
Anyway, since the torque of the prop is stronger than that from the engine, the end result will be as you describe it, the boat will roll to port.
mats is offline
Old 03-22-2007 | 01:56 PM
Your are correct...
http://www.perfprotech.com/home/Repowering.
Patrick
Old 03-22-2007 | 08:37 PM
If you are running a lot of power you will be putting more stress on the top bearning cap turning a left hand prop. Something worth considering.
Noise Pollution is offline
Old 03-23-2007 | 05:26 AM
throttleup's Avatar
Another interesting characteristic with single engine boats is the tendency to list in the opposite direction as the rotation of the prop when the motor is near it's torque peak.
Many applications when run at 3500-4000 (depending on the torque peak of the motor) will list to the port, with a RH prop. As the speed and RPM increases the boat will level out. This is because as the engine RPM gets above the torque peak there is less torque at the prop which will allow the boat to level out.
throttleup is offline
Old 03-23-2007 | 07:52 AM
Talking
Originally Posted by Pat McPherson
Not true...
A left hand spinning engine rolls a boat to port unless you mount the engine in backwards.
A right hand prop also rolls a boat to port.
A left hand prop rolls the boat to starboard; the opposite of the engine.
On my boat, I run with a right hand prop. With just one person in the boat, she run nice and level with no tab. The extra weight from the helm and driver on the starboard side offsets the roll to port from the engine and right hand prop.
If I add a passenger riding on the port side, I do need to lower my port tab to keep the boat running level.
You need to screen your passengers a little better!
kennyo is offline
Magic1
Prop Talk
4
06-12-2008 01:17 PM
markku4444
Prop Talk
1
01-15-2008 06:43 PM
dirtlawyer
Fountain
8
06-16-2003 07:43 AM
puder
4
04-25-2003 08:40 AM
boatinbill
07-26-2002 09:58 AM
