Where to get oil lines made up? >
Old 04-08-2007 | 09:53 AM
Steve H's Avatar
artselectricinc.com
Yes I have one hose on each motor leaking a little. I want to replace all of them. I could easily get some standard hoses made up. I thought I should stay with the OEM style of ends because of the gradual 90 degree turn. Where a standard 90 fitting would impede flow? These are not hot rod engines (415 hp) but I do run for extended periods of time at cruise RPM of 3600 to 3800 rpms. Would standard ends be OK? Or should I just get OEM stuff? If I could get just the ends a local shop could assemble the hose.
Thanks everyone for the responses!!
Steve H
Steve H is offline
Old 04-09-2007 | 07:46 AM
sleeper_dave's Avatar
Look for a parker store in your area. I had my lines made at a place called Fluid Systems Engineering (aka the parker store) here in the Detroit area.
sleeper_dave is offline
Old 04-10-2007 | 04:10 AM
cig1988's Avatar
Try this.
http://www.parker.com/Markets/Marine/
cig1988 is offline
Old 04-10-2007 | 09:42 AM
Default Hose Ends
The Hose End You Need Is A Parker Push Lok #36982-6-6
45 Degree Inverted Flare. We Have Them In Stk.the Hose You Can Use Is 801-6 Push-lok ,it Comes In Many Colors. You Can Go To Your Local Parker Store Or Call 586-790-8880
Jb-fse is offline
Old 04-10-2007 | 11:53 AM
cuda's Avatar
If there is a Goodyear hose dealer near you, they can make up anything you need. I had the braided trim lines running to my outdrives made by them, and save a bunch over the Merc parts.
cuda is offline
Old 04-10-2007 | 12:35 PM
Steve H's Avatar
artselectricinc.com
Thanks guys for all the help. I just ordered new lines from the Marine Power dealer. Got a pretty good deal six hoses for about 150.00 bucks. Can't complain about that. Thanks again for all the suggestions
Steve
Steve H is offline
dean51267
14
08-05-2006 12:07 AM
formula31
21
06-15-2006 09:46 AM
vandeano
13
08-19-2005 02:06 AM
traviss
4
01-15-2003 11:00 AM
