Mold on seats, boat out of storage. >
Old 04-15-2007 | 06:04 AM
offthefront's Avatar
I would think the stains will eventually fade ...Like it was said some sunlight will help alot ... But if they do have to be replaced .... Mcleod Makes the Interior on the upgraded Baja's ... you can get replacements direct from them ....But I expect they will clean up ....m
offthefront is offline
Old 04-15-2007 | 07:06 AM
G Man's Avatar
Thanks, did what the storage facility said. Charcoal, lysol. Live in eastera Pa. Had the boat in an underground mine. Temp constant 50-55 degrees.
G Man is offline
Old 04-15-2007 | 08:01 AM
I was thinkin ... did you clean the boat up right before you put it in storage ? Maybe it was still wet .. or water in the Bilge ? If your cover does not breath well the moisure has no place to go ....m
Old 04-15-2007 | 08:07 AM
G Man's Avatar
No, it was dry. Maybe reaction of Franzy and Lysol???
Can you provide more detail on Mcleod? I tried googling it and didn't come up with anything.
G Man is offline
Old 04-15-2007 | 08:28 AM
http://www.mcleoddesign.com/Sub/Products.html
Old 04-15-2007 | 08:46 AM
Downtown42's Avatar
Had the boat in an underground mine. .
I'd find another place above ground next year.
The sun will eventually bake the chit off with some bleach as stated above.
Downtown42 is offline
Old 04-15-2007 | 09:19 AM
G Man's Avatar
YEah, never again.
thanks !
G Man is offline
Old 04-15-2007 | 10:01 AM
DOWNTOWN42 is right, be patient, bleach solution then as much sunlight as possible, it WILL disappear.
smokinbob is offline
Old 04-15-2007 | 05:56 PM
DORaymond's Avatar
Try some WD-40, I have found it takes everthing off of vinyl.
DORaymond is offline
Old 04-16-2007 | 07:58 AM
Liquid Liability's Avatar
G-Man,
A friend of mine turned me on to a product called JOMAX which is designed specifically to remove stains and permanently kill the microbe's that cause mold and mildew to grow and stain. I had to order it off the internet, but it works great. Best of luck.
Liquid Liability is offline
