SBC Cam question. >
SBC Cam question.
SBC Cam question.
Old 04-15-2007 | 08:37 PM
Full Force's Avatar
The engine pic was last spring with the dart heads on my non roller stock block, best thing on this boat is I can take the sun deck and rear bench apart to access engine!
Full Force is offline
Old 04-16-2007 | 06:05 AM
In case you wanted some Merc comparrison info, the following is from Merc HP 377 EFI stroker service manual:
- 350HP
- 9:1 comp ratio
- Lunati Crank 4.0 X 3.75
- Cam w/1.5:1 Roller rockers: Lift: .510/.530 Dur@50: 222/230
- Vortec Heads - small valve (must be modified)
If you'd like more info, just ask and will try to find it.
John_S is offline
Old 04-16-2007 | 06:09 AM
Full Force's Avatar
Originally Posted by John_S
245,
- 350HP
- 9:1 comp ratio
Cool, it seems like this should work OK, like I said I am on a budget here, I want a bigger boat in a year or so, I cannot justify spending 5000.00 to build something.
Old 04-16-2007 | 12:05 PM
Good looking boat! When you keep up with them and keep full length covers to keep the sun from baking the gelcoat they stay nice even 20+ years later.
I think you'll be more than happy with the new motor. I just converted to a hyd roller setup and it's well worth it over the flat tappet cams.
Ryan00TJ is offline
Old 04-16-2007 | 07:37 PM
Full Force's Avatar
Thanks!! I actually only have a cockpit cover on it, I am a freak about keeping it clean, the boat is in great shape.
ohmthis
9
12-01-2006 07:43 AM
Full Force
0
04-26-2006 01:07 PM
Liberator21
2
04-11-2006 02:18 PM
Cap206
8
01-10-2006 01:41 AM
SLP
13
11-20-2002 02:21 PM
