water in motor? >
water in motor?
water in motor?
Old 04-26-2007 | 12:30 PM
Originally Posted by Deltarat
DaveO what is the chance that when the motor was put together no one checked to see if the head bolts ran thruogh any water passages on the heads and there for they didn't get sealed properly?
I would say that would have nothing to do with a backfire through the carb
1BIGJIM is offline
Old 04-26-2007 | 12:42 PM
not the backfire but could be why there is water in the motor.The backfire Im guessing is a timming issue.
DAVEO is offline
Old 04-26-2007 | 12:46 PM
What's your water pressure @ 3000, 4000, and 5000 rpm? My Eliminator for whatever reason had extremely high water pressure above 4500 rpm. I could run all day long @ 4000, once I reached 4500 it would leak water pass the intake gaskets every time. Took me a while to figure it out but my water pressure was spiking to 40 lbs . I installed a relief valve and a dump out the rear and never had a problem again, 20lbs. of pressure wot. This might be something to check.
NOMOGOFAST is offline
Old 04-26-2007 | 05:44 PM
Ive heard that also but Im running my pick up through the drive. not an exturnal pick up.
DAVEO is offline
Old 04-26-2007 | 06:23 PM
Mine was through the drive also. Just a thought??? I had the milk shake in the v/c's and breathers. Pulled the intake and the valley looked like pudding.
Old 04-26-2007 | 10:59 PM
I have heard that from more than one person. It might be a good security just to put one in.
DAVEO is offline
Fenderjack
2
06-02-2007 03:51 PM
MarkDonzi
3
02-13-2007 08:07 AM
Dtile
6
11-04-2006 09:53 AM
roooon2
2
08-18-2006 08:39 AM
RJ1340
06-12-2005 11:55 PM
