Poor water circulation?? >
Old 04-27-2007 | 06:13 AM
RJBBC's Avatar
Registered User
Originally Posted by jayhawk261
What type of aftermarket exhaust? We used a Stainless Marine manifold system one time and after losing an engine due to detonation/overheating at a specific cylinder, Stainless Marine told us that sometimes their fittings are too long and bottom out against the internal surface of the manifold. Sure enough, that was the culprit. The engine we lost detonated in the cylinder closest to the blockage, a valve broke and went through the rest of the engine. With the new engine, we cut down the fitting, and no more water flow problem.
The exhaust is a Stainless Marine manifold.
RJBBC is offline
Old 04-27-2007 | 06:14 AM
RJBBC's Avatar
Registered User
Originally Posted by monstaaa
check for the little balls on the spring shaft in the water outlet housing. sometimes they rot out or get stuck, and diminish flow
Thanks, I will try that if it happens again.
RJBBC is offline
Old 04-27-2007 | 10:15 AM
jayhawk261's Avatar
I would check that the fittings are not too long in that event. The fitting we had a problem with was the starboard front. Check them all and see if they are good. If there is one bottoming out, it is an easy fix. Cut the fitting down until the blockage is gone. Good luck!
jayhawk261 is offline
Old 04-27-2007 | 02:39 PM
Vinny P's Avatar
I hate the winter!!
I didnt think that engine has those check balls.
Vinny P is offline
Old 04-28-2007 | 09:14 PM
Any water in the oil?
Quaid24 is offline
Old 04-29-2007 | 07:20 AM
RJBBC's Avatar
Registered User
Went boating yesterday. Started the boat up and sounded fine. After a short cruise and stop I started the engine and it sounded funny again. I turned the Captain's Call ON/OFF a few times and then it sounded fine. The oil looks good. I am almost positve the port side Corsa Captain's Call internal diverter is sticking in the closed position.
RJBBC is offline
Old 04-29-2007 | 09:22 AM
Had a very similar problem. I had a bad relay on the Corsa wiring. 1 side open, 1 side closed. On my set up corsa had two relays 1 for each diverter solenoid. Now there is only 1, and a lot less wire. Works good now.
Old Navy is offline
Old 04-29-2007 | 10:51 AM
Yes. If water flow was a problem the manifold would get noticably hot.
Pismo10 is offline
Feelin Nauti
2
05-22-2007 04:40 PM
Shah Mat
1
07-07-2006 09:40 AM
berns29scarab
4
11-09-2004 06:44 PM
BillR
6
05-05-2004 02:04 PM
Nordicflame
1
05-23-2003 05:55 PM
