MSD Shift Interupter on Bravo 1? >
Old 04-26-2007 | 07:01 PM
Question MSD Shift Interupter on Bravo 1?
Has anybody used a MSD Shift Interupter on a Bravo 1? I bought one thinking it would come with some sort of switch but it is apparently designed for the Alpha drive which has a shift interupter from factory but this is usually disabled when you convert the stock ingnition to an MSD ignition. It has a wire which is supposed to connect to the stock interupt switch - but my drive doesn't have one.
I'm still thinking it could be used if I could figure out how to rig a momentary switch (or 2) on the shifter (or bracket) somehow so that when I shift from neutral to forward or reverse it will activate the ignition interupt. I would like to use this because with the cam I'm running (255 deg int. dur @ .050") I have to idle up high (1000 Rpm) to keep it from stalling when I shift it and I know that the B-1 don't like that. Any ideas/advice would be appreciated.
HARDCORE A/O is offline
Old 04-27-2007 | 11:52 AM
You don't need one with Bravo drives it will be a waste of money
Badtoon is offline
Old 04-28-2007 | 06:04 AM
monstaaa's Avatar
just use the alpha cable bracket with the wiring and the switch already there.
monstaaa is offline
YOLO
05-07-2008 10:15 AM
z9er
Drives and Lower Units
5
07-24-2007 06:30 PM
Mkeller
12
06-27-2006 08:44 AM
Sean Sheppard
9
03-07-2005 10:17 AM
stevel
0
05-18-2002 09:28 AM
