MAT Sensor question >
MAT Sensor question
MAT Sensor question
Old 04-29-2007 | 11:21 AM
Registered User
Default MAT Sensor question
I've got a 99 454 MPI, that I've been have a few problems. It starts & idles fine. As it warms & I run it up to about 2000 rpms, it starts loading up & trying to stall, basically running rich. I found that my regulator was bad, replaced it, it did help, but not with the rich condition. Yesterday, I removed my MAT Sensor, & ohm'd it out. It is open, no resistance at all. I then put a heat gun on it to warm it up, no change. So, it definetly appears to be bad, but my question is, will this cause the rich condition? I'm thinking it will, I'm just looking for a second opinion from folks much more advance than myself.
rangerrick63 is offline
Old 04-29-2007 | 01:53 PM
Dave_N's Avatar
Yes, a bad IAT can affect the way the engine runs. You can purchase a resistor and temporarily put it in place of the IAT to see if your probelm clears up. A 1.8k resistor will simulate 100 degree intake air temp.
Dave
Dave_N is offline
Old 04-29-2007 | 05:09 PM
I'ts probably your CTS sensor (coolant temp sensor).
Old Ride is offline
Old 04-29-2007 | 06:26 PM
Registered User
Thanks for the input, I had wondered if I could simulate the proper temp. I assume I should be able to get the resistor from Radio Shack, or any other electronic supply, I do that tomorrow.
As for the CTS, I have it removed, & I do believe I am going to change it, considering the price is only about $25, I don't think I can go wrong with a new one.
Old 04-30-2007 | 06:58 AM
Michigan Mad Man
Put a scan tool on and check the codes.
TylerCrockett is offline
Old 05-01-2007 | 04:28 PM
Registered User
Dave
Dave, Thanks for the tip, I think that had to be the cheapest "test" tool I've ever bought, .99...& it worked great. I simply plugged it in & the fired the boat up, it ran perfect, just like it should. I ordered the IAT switch, & it will be here tomorrow or Thurs. Thanks again
Old 08-06-2007 | 07:40 AM
Default Temp
Is there 2 temp. sensors on 95 350 mpi one for the ECM and one for the gauge on dash? Because mine is doing the same thing running very rich and barly idles. Any input
Spooln is offline
Wazzup Racing
Super Boat International
7
11-17-2007 08:07 AM
Rage
11
08-06-2007 01:44 PM
jdub
Detailing, Painting, & Fiberglass
9
02-09-2007 07:54 AM
Shah Mat
1
05-22-2006 10:50 AM
Dave M
5
05-14-2006 12:35 PM
