gil exhaust
Old 05-07-2007 | 10:59 PM
27daytona's Avatar
Default gil exhaust
I was timing my former boat for a buddy and noticed that the top of the ss riser out of the gil exhaust log was hot but only on the top of the inboard riser. It was not hot on the bottom of the same riser and the other riser was cold. Any imput would be appreciated. Thanks Doug
27daytona is offline
Old 05-08-2007 | 12:00 PM
mats's Avatar
My experience with Gil with SS risers is that they sometimes get hot on the top of the elbows. Especially if the impeller is a few years old. I has not caused any problems so far.
mats is offline
Old 05-09-2007 | 07:47 AM
axapowell's Avatar
Where To
Bring up the RPM's and see if it cools down. No more then 1800. Not on a hose...right? If that doesn't cool it down, flush the exhaust real good and make sure there isn't any blockage. Could be an impeller as already noted.
Dave
axapowell is offline
Old 05-09-2007 | 07:52 AM
We usually recommend welding up a few holes on the bottom of the riser dump to force the water to the top. Gravity will take care of the bottom.
BROWNIE is offline
Old 05-09-2007 | 08:25 AM
27daytona's Avatar
Thanks guys, I'll try all of these things. Doug
Old 05-09-2007 | 08:56 AM
On my Gil's, I figured out that a chunk of powder coat inside the manifold broke loose and was restricting the water flow at the manifold fitting to to the jump hose. You may have to remove the fitting to be able to see. Removed it with pliers and everything was good.
BenPerfected is offline
formula 382 sr-1
0
10-07-2007 05:58 PM
gripit
2
01-08-2007 07:25 PM
Gary864
06-07-2006 06:39 PM
nocigarette
8
04-24-2006 06:59 AM
Dangerous Dave
5
08-02-2004 10:25 AM
